I think this does not need any wiring diagram since LittleFS runs on internal memory of the ESP32. As I mentioned I tried using the LittleFS test code which is:
#include <Arduino.h>
#include "FS.h"
#include <LittleFS.h>
/* You only need to format LittleFS the first time you run a
test or else use the LITTLEFS plugin to create a partition
If you test two partitions, you need to use a custom
partition.csv file, see in the sketch folder */
//#define TWOPART
#define FORMAT_LITTLEFS_IF_FAILED true
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
Serial.printf("Listing directory: %s\r\n", dirname);
File root = fs.open(dirname);
if (!root) {
Serial.println("- failed to open directory");
return;
if (!root.isDirectory()) {
Serial.println(" - not a directory");
return;
File file = root.openNextFile();
while (file) {
if (file.isDirectory()) {
Serial.print(" DIR : ");
Serial.println(file.name());
if (levels) {
listDir(fs, file.path(), levels - 1);
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print("\tSIZE: ");
Serial.println(file.size());
void createDir(fs::FS &fs, const char *path) {
Serial.printf("Creating Dir: %s\n", path);
if (fs.mkdir(path)) {
Serial.println("Dir created");
Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char *path) {
Serial.printf("Removing Dir: %s\n", path);
if (fs.rmdir(path)) {
Serial.println("Dir removed");
Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char *path) {
Serial.printf("Reading file: %s\r\n", path);
File file = fs.open(path);
if (!file || file.isDirectory()) {
Serial.println("- failed to open file for reading");
return;
Serial.println("- read from file:");
while (file.available()) {
Serial.write(file.read());
file.close();
void writeFile(fs::FS &fs, const char *path, const char *message) {
Serial.printf("Writing file: %s\r\n", path);
File file = fs.open(path, FILE_WRITE);
if (!file) {
Serial.println("- failed to open file for writing");
return;
if (file.print(message)) {
Serial.println("- file written");
Serial.println("- write failed");
file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
Serial.printf("Appending to file: %s\r\n", path);
File file = fs.open(path, FILE_APPEND);
if (!file) {
Serial.println("- failed to open file for appending");
return;
Serial.println("- message appended");
Serial.println("- append failed");
file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2) {
Serial.printf("Renaming file %s to %s\r\n", path1, path2);
if (fs.rename(path1, path2)) {
Serial.println("- file renamed");
Serial.println("- rename failed");
void deleteFile(fs::FS &fs, const char *path) {
Serial.printf("Deleting file: %s\r\n", path);
if (fs.remove(path)) {
Serial.println("- file deleted");
Serial.println("- delete failed");
// SPIFFS-like write and delete file, better use #define CONFIG_LITTLEFS_SPIFFS_COMPAT 1
void writeFile2(fs::FS &fs, const char *path, const char *message) {
if (!fs.exists(path)) {
if (strchr(path, '/')) {
Serial.printf("Create missing folders of: %s\r\n", path);
char *pathStr = strdup(path);
if (pathStr) {
char *ptr = strchr(pathStr, '/');
while (ptr) {
*ptr = 0;
fs.mkdir(pathStr);
*ptr = '/';
ptr = strchr(ptr + 1, '/');
free(pathStr);
Serial.printf("Writing file to: %s\r\n", path);
if (!file) {
return;
file.close();
void deleteFile2(fs::FS &fs, const char *path) {
Serial.printf("Deleting file and empty folders on path: %s\r\n", path);
if (pathStr) {
char *ptr = strrchr(pathStr, '/');
if (ptr) {
Serial.printf("Removing all empty folders on path: %s\r\n", path);
while (ptr) {
*ptr = 0;
fs.rmdir(pathStr);
free(pathStr);
void testFileIO(fs::FS &fs, const char *path) {
Serial.printf("Testing file I/O with %s\r\n", path);
static uint8_t buf[512];
size_t len = 0;
if (!file) {
return;
size_t i;
Serial.print("- writing");
uint32_t start = millis();
for (i = 0; i < 2048; i++) {
if ((i & 0x001F) == 0x001F) {
Serial.print(".");
file.write(buf, 512);
Serial.println("");
uint32_t end = millis() - start;
Serial.printf(" - %u bytes written in %" PRIu32 " ms\r\n", 2048 * 512, end);
file.close();
start = millis();
end = start;
i = 0;
if (file && !file.isDirectory()) {
len = file.size();
size_t flen = len;
start = millis();
Serial.print("- reading");
while (len) {
size_t toRead = len;
if (toRead > 512) {
toRead = 512;
file.read(buf, toRead);
if ((i++ & 0x001F) == 0x001F) {
Serial.print(".");
len -= toRead;
Serial.println("");
Serial.printf("- %lu bytes read in %" PRIu32 " ms\r\n", (unsigned long)flen, end);
file.close();
#ifdef TWOPART
if (!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED, "/lfs2", 5, "part2")) {
Serial.println("part2 Mount Failed");
return;
appendFile(LittleFS, "/hello0.txt", "World0!\r\n");
readFile(LittleFS, "/hello0.txt");
LittleFS.end();
Serial.println("Done with part2, work with the first lfs partition...");
#endif
if (!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED)) {
Serial.println("LittleFS Mount Failed");
return;
Serial.println("SPIFFS-like write file to new path and delete it w/folders");
writeFile2(LittleFS, "/new1/new2/new3/hello3.txt", "Hello3");
listDir(LittleFS, "/", 3);
deleteFile2(LittleFS, "/new1/new2/new3/hello3.txt");
createDir(LittleFS, "/mydir");
writeFile(LittleFS, "/mydir/hello2.txt", "Hello2");
listDir(LittleFS, "/", 1);
deleteFile(LittleFS, "/mydir/hello2.txt");
removeDir(LittleFS, "/mydir");
writeFile(LittleFS, "/hello.txt", "Hello ");
appendFile(LittleFS, "/hello.txt", "World!\r\n");
readFile(LittleFS, "/hello.txt");
renameFile(LittleFS, "/hello.txt", "/foo.txt");
readFile(LittleFS, "/foo.txt");
deleteFile(LittleFS, "/foo.txt");
testFileIO(LittleFS, "/test.txt");
deleteFile(LittleFS, "/test.txt");
Serial.println("Test complete");
void loop() {}
Which the Serial Monitor while running this code:
E (3) esp_littlefs: ./managed_components/joltwallet__littlefs/src/littlefs/lfs.c:1383:error: Corrupted dir pair at {0x0, 0x1}
E (3) esp_littlefs: mount failed, (-84)
E (7) esp_littlefs: Failed to initialize LittleFS
