Hello,
I have created a program that works with an Arduino Nano ESP32 and an ESP8266. Now I have a new XIAO ESP32S3 and LittfeFS does not work. I use Serial and D2, D3, D4 and D6 for leds.
E (6867) esp_littlefs: ./managed_components/joltwallet__littlefs/src/littlefs/lfs.c:1384:error: Corrupted dir pair at {0x0, 0x1}
E (6867) esp_littlefs: mount failed, (-84)
E (6871) esp_littlefs: Failed to initialize LittleFS
[ 7036][E][LittleFS.cpp:79] begin(): Mounting LittleFS failed! Error: -1
File read: /configuration.txt[ 7042][E][vfs_api.cpp:106] exists(): File system is not mounted
not successful, file does not exist.
Complete verbose output here
Compile Date/Time : Jan 30 2025 18:04:22
Compile Host OS : windows
ESP-IDF Version : v5.3.2-282-gcfea4f7c98-dirty
Arduino Version : 3.1.1
Board Info:
Arduino Board : XIAO_ESP32S3
Arduino Variant : XIAO_ESP32S3
Arduino FQBN : esp32:esp32:XIAO_ESP32S3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=default_8MB,DebugLevel=verbose,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=all,JTAGAdapter=default
============ Before Setup End ============
[ 2017][I][esp32-hal-periman.c:141] perimanSetPinBus(): Pin 19 already has type USB_DM (45) with bus 0x3fc96c10
[ 2017][I][esp32-hal-periman.c:141] perimanSetPinBus(): Pin 20 already has type USB_DP (46) with bus 0x3fc96c10
ESP32 RESET
object Anzahl 2
singleObjectZeitAnzahl 10
singleObjectLength 168
Anzahl Dimstufen 150
[ 7048][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type LEDC (9) successfully set to 0x42006588
[ 7059][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 3 successfully set to type LEDC (9) with bus 0x3fc9d374
[ 7069][I][esp32-hal-ledc.c:166] ledcAttachChannel(): LEDC attached to pin 3 (channel 0, resolution 10)
[ 7078][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type LEDC (9) successfully set to 0x42006588
[ 7089][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 4 successfully set to type LEDC (9) with bus 0x3fc9d390
[ 7099][I][esp32-hal-ledc.c:166] ledcAttachChannel(): LEDC attached to pin 4 (channel 1, resolution 10)
[ 7109][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type LEDC (9) successfully set to 0x42006588
[ 7120][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 5 successfully set to type LEDC (9) with bus 0x3fc9d3ac
[ 7130][I][esp32-hal-ledc.c:166] ledcAttachChannel(): LEDC attached to pin 5 (channel 2, resolution 10)
[ 7139][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type LEDC (9) successfully set to 0x42006588
[ 7150][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 43 successfully set to type INIT (0) with bus 0x0
[ 7160][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 43 successfully set to type INIT (0) with bus 0x0
[ 7169][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 43 successfully set to type LEDC (9) with bus 0x3fc9d3c8
[ 7180][I][esp32-hal-ledc.c:166] ledcAttachChannel(): LEDC attached to pin 43 (channel 3, resolution 10)
=========== After Setup Start ============
INTERNAL Memory Info:
Total Size : 394660 B ( 385.4 KB)
Free Bytes : 356836 B ( 348.5 KB)
Allocated Bytes : 32600 B ( 31.8 KB)
Minimum Free Bytes: 353724 B ( 345.4 KB)
Largest Free Block: 286708 B ( 280.0 KB)
GPIO Info:
GPIO : BUS_TYPE[bus/unit][chan]
3 : LEDC[0][0]
4 : LEDC[0][1]
5 : LEDC[0][2]
19 : USB_DM
20 : USB_DP
43 : LEDC[0][3]
44 : UART_RX[0]
============ After Setup End =============
IDE is Arduino IDE 2.3.4 with Espressif ESP32 Core Package 3.1.1
Board Setting are all default.
What can I do?
