ESP32 Mouse + Keyboard (incl. Media) at the same time
Hello,
I want to use the HID Mouse and Keyboard functionallity - incl. Media function - at the same time.
The library from T-vK support either Mouse or Keyboard - not at the same time.
Afterwards I found two similar librarys from
jakern, support of media keys, but this library has problems with the mouse - no function - reconnect?
blackketter, has solved mouse reconnect, keyboard and mouse is working, but no Media Keys
Does anybody knows a library with supports Mouse+Keyboard+Media. I'm not able to combine the functionallity of both libraries - I tried it, but I failed.
Regards, Arduino4Fun
Hi again,
now I took the library from blackketter as a base and added the lines from jakern ... in ...
bleKeyboardInstance->connectionStatus->inputMediaKeys = bleKeyboardInstance->inputMediaKeys;
BleComboKeyboard.cpp
BLECharacteristic* inputMediaKeys;
BleConnectionStatus.h
Now it seems, that it works -> Mouse + Keyboard + Media
But there is still a difference in BleConnectionStatus.cpp
blackketter
#include "BleConnectionStatus.h"
BleConnectionStatus::BleConnectionStatus(void) {
void BleConnectionStatus::onConnect(BLEServer* pServer)
  this->connected = true;
  BLE2902* desc = (BLE2902*)this->inputKeyboard->getDescriptorByUUID(BLEUUID((uint16_t)0x2902));
  desc->setNotifications(true);
  desc = (BLE2902*)this->inputMouse->getDescriptorByUUID(BLEUUID((uint16_t)0x2902));
void BleConnectionStatus::onDisconnect(BLEServer* pServer)
  this->connected = false;
  desc->setNotifications(false);
jakern
  desc = (BLE2902*)this->inputMediaKeys->getDescriptorByUUID(BLEUUID((uint16_t)0x2902));
At the moment I only use the implementation of Blackketter including the two lines. I'm not sure if I still need adjustments in BleConnectionStatus.cpp for MediaKeys support.
I would be happy to receive advice on this solution or if someone sees difficulties.
Best regards, Arduino4Fun
And again,
after Media Keys not reconnected after plug off/on, now I combined the two files to
Now also reconnect of Media Keys are working - hopefully no all works fine...
The function KEY_MEDIA_MUTE, KEY_MEDIA_PLAY_PAUSE, KEY_MEDIA_NEXT_TRACK are working as wanted. But when sending
Keyboard.write( KEY_MEDIA_VOLUME_UP );
and
Keyboard.write( KEY_MEDIA_VOLUME_DOWN );
lead to blocking PC. I'm not able to switch from window to window by ALT+TAB after sending this commands. It takes a while for the PC to react normally again. Strange.
