Bonjour
L'ESP32 capture temperarure, pression, humidité et l'envoie au php qui maj la base de donnée mysql
Malgré un retour http code =200 la bdd n'est pas mise à jour.
Avec ce même fichier php, je lui envoie un formulaire html : la bdd est maj:
voici la partie code arduino ![]()
WiFiClientSecure *client = new WiFiClientSecure;
client->setInsecure(); //don't use SSL certificate
HTTPClient https;
// Your Domain name with URL path or IP address with path
//https.begin(*client, serverName);
// Specify content-type header
https.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Prepare your HTTP POST request data
String httpRequestData = "api_key=" + apiKeyValue + "&TEMP_BURO=" + String(temp)
+ "&HUM_BURO=" + String(hum) + "&PRESS_BURO=" + String(pres) + "";
Serial.print("httpRequestData: ");
Serial.println(httpRequestData);
// Send HTTP POST request
int httpResponseCode = https.POST(httpRequestData);
Serial.println("POST POST POST");
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
else {
Serial.print("Error code: ");
// Free resources
https.end();
else {
Serial.println("WiFi Disconnected");
//Send an HTTP POST request every 5 seconds
delay(15000);
WiFi.disconnect();
Serial.println("----------------------");
Serial.println("Rentre en mode Deep Sleep");
esp_deep_sleep_start();
Voici la sortie serie :
Connected to WiFi network with IP Address: 192.168.1.35
temperature :20.00
humidité :50.50
Pression :1024.04
httpRequestData: api_key=jghghghghghghghgh&TEMP_BURO=20.00&HUM_BURO=50.50&PRESS_BURO=1024.04
POST POST POST
HTTP Response code: 200
Voici le code du php :
if (isset($_POST["api_key"]) && isset($_POST["TEMP_BURO"]) && isset($_POST["HUM_BURO"]) && isset($_POST["PRESS_BURO"])) {
$api_key = test_input($_POST["api_key"]);
if($api_key == $api_key_value) {
echo 'Api Key OK<br>';
$TEMP_BURO = test_input($_POST['TEMP_BURO']);
$HUM_BURO = test_input($_POST['HUM_BURO']);
$PRESS_BURO = test_input($_POST['PRESS_BURO']);
$servname = "localhost";
$dbname = "my_dbname";
$user = "my_user";
$pass = "passxxxxxxxxxxxxxxxx";
try{
$dbco = new PDO("mysql:host=$servname;dbname=$dbname", $user, $pass);
$dbco->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
echo '2222222222<br>';
$sql = "INSERT INTO SENSOR_BURO ( TEMP_BURO, HUM_BURO, PRESS_BURO)
VALUES ('" . $TEMP_BURO . "', '" . $HUM_BURO . "', '" . $PRESS_BURO . "')";
$dbco->exec($sql);
echo 'Entrée ajoutée dans la table';
$dbco = null;
catch(PDOException $e){
echo "Erreur : " . $e->getMessage();
function test_input($data) {
$data = trim($data);
$data = stripslashes($data);
$data = htmlspecialchars($data);
return $data;
Où est l'erreur ?
Merci de votre aide
Daniel
