ESP32 S3 Clone wierd thing in com port
i have a problem with this board i use cable type a to type c it work in 2 port fine but when come to use cable type c to type c it work in port usb-otg good but in other port com(uart) happen wierd thing imagine the cable each end of cable will name one (a) and other end (b) if am connect (a) to laptop and (b) to board will not work but if rotate end b and connect to board com port work good and and am try to use other cable same thing happen and am try to test a 4 resistor 2 connect to com and 2 connect to usb-otg in com port pin name cc1 will get 0.02ohm but in other 3 pin cc2 of com port and cc1,cc2 of usb-otg am get from5.8 to 5.11
my question is this okay or not becuase same port of lap same cable when connect to phone it work fine
I moved your topic to a more appropriate forum category @hossammohamed.
The Nano Family > Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, when creating a topic please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
Perhaps this link will help, the two USB ports are different and can be changed via the tools menu
https://www.espboards.dev/blog/why-esp32-dev-boards-2-usb-c/
you reply of link you give is help full and very clear in explain but dont ansrew my question
I don't understand what you are saying so I gave background info. As a new user you should start by reading and following the advice in the pinned post re 'How to get the most from the forum.
thanks for try you help
