ESP32-S3-DevKitC-1 compiling error
Hi all,
I've encountered this error message while compiling. Please assist.
"In file included from c:\users\rapsodo\onedrive - rapsodo\desktop\documents\arduinodata\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32s3-elf\include\c++\8.4.0\stdlib.h:36,
from C:\Users\Rapsodo\OneDrive - Rapsodo\Desktop\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32s3/include/newlib/platform_include/assert.h:21,
from c:\users\rapsodo\onedrive - rapsodo\desktop\documents\arduinodata\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32s3-elf\sys-include\sys\reent.h:503,
from C:\Users\Rapsodo\OneDrive - Rapsodo\Desktop\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32s3/include/newlib/platform_include/sys/reent.h:17,
from c:\users\rapsodo\onedrive - rapsodo\desktop\documents\arduinodata\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32s3-elf\sys-include\stdio.h:60,
from C:\Users\Rapsodo\OneDrive - Rapsodo\Desktop\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.6\cores\esp32/Arduino.h:27,
from sketch\sketch_jan10a.ino.cpp:1:
c:\users\rapsodo\onedrive - rapsodo\desktop\documents\arduinodata\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32s3-elf\include\c++\8.4.0\cstdlib:41:10: fatal error: bits/c++config.h: No such file or directory
#include <bits/c++config.h>
compilation terminated.
exit status 1
Error compiling for board ESP32S3 Dev Module.
This is the code that i ran:
"#define LED_R 5
#define LED_G 6
#define LED_B 7
pinMode(LED_R, OUTPUT);
pinMode(LED_G, OUTPUT);
pinMode(LED_B, OUTPUT);
digitalWrite(LED_R, LOW);
digitalWrite(LED_G, LOW);
digitalWrite(LED_B, LOW);
digitalWrite(LED_R, HIGH);
digitalWrite(LED_G, HIGH);
digitalWrite(LED_B, HIGH);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
the code compiles and runs for me **-- on an Arduino and it compiled when i specified an "ESP32 Dev Module" board
looks like your installation is missing a file.
what did you install to compile/run your code? which IDE?
