I’m using an RM68140 3.5-inch touch shield, and it works great with Arduino Uno R3/R4.
However, when I switch to an ESP32-S3 Uno-form board, the display works fine but the touch function doesn’t.
I’m using the DIYables TFT Touch Shield library.
Has anyone experienced this issue?
https://github.com/DIYables/DIYables_TFT_Touch_Shield
Touch Get Point Example
This example demonstrates how to read and display touch coordinates using the DIYables TFT Touch Shield.
When you touch the screen, the code prints the mapped (screen) X and Y coordinates to the Serial Monitor
and draws a red dot at the touched location.
**Note:**
The touch screen works with default calibration values.
Just in case the touch does not work properly, run the `TouchCalibration` example
and set the calibration values in the code using `setTouchCalibration()`.
Provided by DIYables
This example code is in the public domain
Product page:
- https://diyables.io/products/3.5-tft-lcd-color-touch-screen-shield-for-arduino-uno-mega-320x480-resolution-ili9488-driver-parallel-8-bit-interface-28pin-module-with-touch
- https://www.amazon.com/dp/B0DQ3NQ3LW
#include <DIYables_TFT_Touch_Shield.h>
#define RED DIYables_TFT::colorRGB(255, 0, 0)
#define WHITE DIYables_TFT::colorRGB(255, 255, 255)
// (Optional) Calibration values. Just in case touch does not work properly,
// run the TouchCalibration example and update the values below.
#define LEFT_X 136
#define RIGHT_X 907
#define TOP_Y 942
#define BOT_Y 139
// For Arduino Uno R3, Uno R4, Mega, Due, Giga, DIYables STEM V3/V4 (default touch pins: XP=6, YP=A1, XM=A2, YM=7)
//DIYables_TFT_RM68140_Shield TFT_display;
// For DIYables ESP32-S3 Uno-form factor (https://diyables.io/esp32-s3-uno), touch pins: XP=3, YP=1, XM=7, YM=14
DIYables_TFT_RM68140_Shield TFT_display(3, 1, 7, 14);
TFT_display.begin();
// Set the rotation (0 to 3)
TFT_display.setRotation(0);
TFT_display.fillScreen(WHITE);
TFT_display.setTouchCalibration(LEFT_X, RIGHT_X, TOP_Y, BOT_Y);
Serial.println("Touch the screen to see coordinates.");
int x, y;
if (TFT_display.getTouch(x, y)) {
Serial.print("Touch at: ");
Serial.print(x);
Serial.print(", ");
Serial.println(y);
TFT_display.fillCircle(x, y, 4, RED); // Draw a red dot where touched
delay(200); // Debounce
