ESP32 SD card initialization failed
I am working with the ESP32 One, which has onboard SD-card and camera. When using the SD-card without using the camera it works fine, but when trying to save pictures from the camera to the sd-card, the sd-card mount failed.
#include "esp_camera.h"
#include "FS.h"
#include "SD.h"
#include <SPI.h>
#define SCK  14
#define MISO  12
#define MOSI  13
#define CS  15
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
#include "camera_pins.h"
unsigned long lastCaptureTime = 0; // Last shooting time
int imageCount = 1;                // File Counter
bool camera_sign = false;          // Check camera status
bool sd_sign = false;              // Check sd status
// Save pictures to SD card
void photo_save(const char * fileName) {
  // Take a photo
  camera_fb_t *fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Failed to get camera frame buffer");
    return;
  // Save photo to file
  writeFile(SD, fileName, fb->buf, fb->len);
  // Release image buffer
  esp_camera_fb_return(fb);
  Serial.println("Photo saved to file");
// SD card write file
void writeFile(fs::FS &fs, const char * path, uint8_t * data, size_t len){
    Serial.printf("Writing file: %s\r\n", path);
    File file = fs.open(path, FILE_WRITE);
    if(!file){
        Serial.println("Failed to open file for writing");
        return;
    if(file.write(data, len) == len){
        Serial.println("File written");
        Serial.println("Write failed");
    file.close();
void initializeSDCard() {
  SPIClass spi = SPIClass(HSPI);
  spi.begin(SCK, MISO, MOSI, CS);
  if (!SD.begin(CS, spi, 80000000)) {
    Serial.println("SD Card mount failed");
    return;
    Serial.println("SD Card initialized");
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD Card found");
    return;
  Serial.print("SD Card Type: ");
  if(cardType == CARD_MMC){
      Serial.println("MMC");
  } else if(cardType == CARD_SD){
      Serial.println("SDSC");
  } else if(cardType == CARD_SDHC){
      Serial.println("SDHC");
      Serial.println("UNKNOWN");
  Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
  Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
  sd_sign = true;
  initializeSDCard();
  sd_sign = true; // sd initialization check passes
    //When the serial monitor is turned on, the program starts to execute
    //needs to comment out, when working with LiPo
  //while(!Serial);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  //config.frame_size = FRAMESIZE_UXGA;
  config.frame_size = FRAMESIZE_SVGA;
  config.pixel_format = PIXFORMAT_JPEG; // for streaming
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if(config.pixel_format == PIXFORMAT_JPEG){
    if(psramFound()){
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
      // Limit the frame size when PSRAM is not available
      config.fb_location = CAMERA_FB_IN_DRAM;
    // Best option for face detection/recognition
    config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  camera_sign = true; // Camera initialization check passes
  Serial.println("Photos will begin");
  // Camera & SD available, start taking pictures
  if(camera_sign && sd_sign){
    // Get the current time
    unsigned long now = millis();
    // Take two pictures per second, take a picture and save it to the SD card
    // 500 milliseconds = 2 pictures per second
    if ((now - lastCaptureTime) >= 500) {
      char filename[32];
      sprintf(filename, "/image%d.jpg", imageCount);
      photo_save(filename);
      Serial.printf("Saved picture: %s\r\n", filename);
      imageCount++;
      lastCaptureTime = now;
are you sure you have the SD card SPI pin definitions correct
I used
// SPI pins for ESP32-CAM SD card
#define SCK 14  // HS2_CLK
#define MISO 2  // HS2_DATA0
#define MOSI 15 // HS2_CMD
#define CS 13   // HS2_DATA3
which worked OK
Thank you very much. I think so.
Have you also used the Waveshare ESP32 One?
no - I miss read post 1 thinking it referred to a ESP32-CAM
you SPI definitions in post 1 look correct so no idea what is wrong
maybe worth updating post title to reflect the question is about a Waveshare ESP32 One
