ESP32 sending string to Arduino Uno
There are strings from Node-RED I want to send, from the ESP32, to an Uno.
// Master sender ESP32
#define RXD2 16
#define TXD2 17
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
shape = "1,2,3";
numOfElements = (shape.length());
char charbuffer[numOfElements];
shape_sequence.toCharArray(charbuffer, numOfElements);
while (Serial2.available()) {
  Serial2.write(charbuffer); //Write the serial data
Uno:
//Receiver Code
char str[4];
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(9600); // initialize UART with baud rate of 9600 bps
  //  digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
  //  delay(1000);                     // wait for a second
  //  digitalWrite(LED_BUILTIN, LOW);  // turn the LED off by making the voltage LOW
  int i = 0;
  if (Serial.available()) {
    delay(100); //allows all serial sent to be received together
    while (Serial.available() && i < 4)
      str[i++] = Serial.read();
    str[i++]='\0';
  if (i > 0)
    Serial.println(str);
Is there a way to tell if the characters are being sent? I don't think I can use the serial monitor. Should I try to output something using the built-in LED on the Uno?
Pin TX2 of the ESP32 is connected to a bidirectional logic level shifter that outputs to the RX pin of the Uno.
adamelli:
According to the schematic you posted, IMHO, you have NOT connected the bidirectional logic level shifter correctly.
LV -> ESP32 3.3V
HV -> Uno 5V
GND -> ESP32 & UNO GND (this is correct)
A1 -> ESP32 UART2 TX
B1 -> Uno RX.
Schematic
hope that helps...
LV -> 3.3V (either)
HV -> 5V Uno
B1 -> Uno RX
https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide/all
Thanks.
print?
Serial.print and not Serial.write?
Your sending code does not compile, so it is not totally clear what you are doing.
Can you confirm what is in charbuffer before you try and send it? Is is null terminated?
#include <HardwareSerial.h>
//  Serial.begin(115200);
  Serial2.begin(9600, SERIAL_8N1, 16, 17);
  delay(100);
    String shape = "1,2,3";
    Serial2.println(shape);
//RX0 is now RX1 of Mega.
//Receiver Mega
  Serial1.begin(9600);
  Serial.begin(19200);
  delay(100);
  if(Serial1.available())
    String received = "";
    received = Serial1.readString();
    Serial.println(received);
Is there something in either sketch that should be changed?
What do you see when you run it?
Switching to the mega with the additional serial ports is a good idea.
I think that the level shifter is a good idea, as the output of the esp tx2 may not adequately drive the mega Rx
EDIT: You may do better with
received = Serial1.readStringUntil('\n');
cattledog:
//Receiver Mega
  delay(100);
  if (Serial1.available()) {
It's about how Serial.readString() works: it reads from the serial port forever in this case. It stops reading if the serial interface is given a time-out. There are two possibilities:
  • use readStringUntil() on the receiver
  • call mySerial.setTimeout(300); (from setup()) to set a 300ms (for instance, as long as it's significantly less than 1000) time out on the receiver — it defaults to one second!
Yes, there is a bit problem when the .readString() timeout is longer than the period between messages.
You control the sent message and add the '\n' terminator.
My preference is to use the readStringUntil('\n') instead of setting a timeout less than the transmission period.
I don't know where you are headed with this program, but on the Mega it would be safer to use either c-strings(null terminated character arrays with reserved memory) or the .reserve() method with String objects.
Depending on what is happening on the Mega other than reading the message from the ESP32, the final program might benefit from non-blocking reading methods on the Mega.
In my testing, I did not need the level shifter between the ESP32 tx and Arduino rx.
Neither of these are 'safe'. Strings are advised against on Arduino and low level c-strings are very pone to coding errors.
Processing using C character arrays is a major source of program crashes
My SafeString library solves both these issues. i) is provides a replacement for Arduino Strings without the memory issues but with the functionality and better error checking and error messages ii) Avoids have to use low level c-string processing (which was way C++ Strings were created)
There is a detailed tutorial on SafeStrings and many example in the library available from the Arduino library manager.
The SafeString library includes a SafeStringReader which makes it easy to read lines of data, with optional timeout and echo.
All of the SafeString methods are non-blocking as is the SafeStringReader (even when you specify a read timeout)
#include <SafeStringReader.h>
// install SafeString library from the library manager
// see the tutorial https://www.forward.com.au/pfod/ArduinoProgramming/SafeString/index.html
createSafeStringReader(sfReader,120,'\n');  // reads upto 120 char line terminated by \n'
  Serial.begin(115200); // <<<<<<<<<<< make debug output as fast as possible
  Serial1.begin(9600);  // << data connection
  for (int i=10; i>0; i--) {
    Serial.priint(i); Serial.print(' ');
  SafeString::setOutput(Serial); // turn on error msgs
  sfReader.conect(Serial1);  // connect to read from Serial1
  if (sfReader.read()) {
    // got a line of input
    Serial.println(sfReader); // if sfReader echo not turned on
    parseInput();  // use SafeString methods on sfReader to extract data
    sfReader.clear(); // for next read
My tutorial Text I/O for the Real World has more details on how to reliably read and write text data in Arduino without blocking the rest of your loop() code
