Here is the code
#include <TFT_eSPI.h> // Hardware-specific library
// In the TFT_ESPI user_setup.h file //&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
// be sure to comment OUT the line for TFT_CS // <======== BE SURE TO DO THIS EVERYTIME A NEW COMPUTER IS USED
// //#define TFT_CS 21 // Chip select control pin // OR the library is Re-installed
// ###!!!!Jan 2024 see notes on ...D:\Eletronica\Arduino\SketchBook\libraries\TFT_eSPI_Setups
// load RF related libraries
//???#include "printf.h" // Added Jan 2024
#include "SPI.h"
#include "nRF24L01.h" // Added Jan 2024
#include "RF24.h"
//???? #include "RF24Network.h" //Commented Jan 2024
//----- Using faster Graphic Library
TFT_eSPI tft = TFT_eSPI(); // Invoke TFT custom library
// *************My setup for Harware SPI for ILI9341***************
// The pins used by the TFT display are defined in the user_setup.h file
// ####### DO NOT ERASE THIS #######
// TFT_MISO 19
// TFT_MOSI 23
// TFT_SCLK 18
// TFT_CS 15
// TFT_DC 2 // Data Command control pin
// TFT_RST 4 // Reset pin (could connect to RST pin)
//----- define RF24L01 variables ###### CHANGED IN JAN 2024######################## nRF24L01 pin definitions changed#####################
#define RF24_CSN 16 // ####### New Radio pinout#######
#define RF24_CE 17 // ####### New Radio pinout#######
//======= in old layout board the pins are:=======
//???#define RF24_CSN 3
//???#define RF24_CE 1
//???uint8_t address[][6] = {"Prime", "1Node", "2Node" }; // using tmhr20 example
long long unsigned addresses[5] = { 0x00D00FAFFA, 0x00D00FAFFB, 0x00D00FAFFC, 0x00D00FAFFD, 0x00D00FAFFE }; // cisterna = pipe0 caixa = pipe1
uint8_t pipeNum; // used in checkPipe() Jan 2024
RF24 radio(RF24_CE,RF24_CSN); // NRF24L01 used SPI pins radio (CE, CSN)
const uint16_t channel = 108; //changed on Marco2021
// Structure of our payload
// ESP32 group data in 4 bytes chunks, so data structure has to be rearranged
//The data to be transmitted by lower and upper water tanks modules is:
// type cisterna caixa superior
// 1 float Irms auxVol (last pumping cycle volume)
// 2 float flow flow
// 3 float Pdisch totalLiters_1
// 4 float DpFilter flowPoco (added July 2023)
// 5 float Pinlet dummy2
// 6 float lampCurrent dummy4 //added in March 2021
// 7 int rawDp rawDp
// 8 bool flapstate dummy3
// In Jan 2024 rev 0 on, dummy variables on Cx Superior will be assigned a value 0f -100, which will
// be used by the receiver to identify the data belongs to Caixa Superior
// ========NO NEED FOR THAT ANYMORE, SINCE WE ARE USING PIPES AND VARIABLES WILL BE CHANGED TO uint16_t =========
struct payload_t // 32 bytes max, used=7*4+2+1 = 31 bytes OK! corrected March 2023
uint32_t counter; // - 4 bytes number of packets transmitted
float val1; // - 4 bytes
float val2; // - 4 bytes
float val3; // - 4 bytes
float val4; // - 4 bytes
float val5; // - 4 bytes
float val6; // - 4 bytes
int16_t val7; // - 2 bytes
bool val8; // - 1 byte
//====================== NEW ========================================
// 0 uint32_t counter counter (number of packets transmitted)
// 1 int16_t Irms_i auxVol_i (last pumping cycle volume)
// 2 int16_t flow_i flow_i
// 3 int16_t Pdisch_i totalLiters_1_i
// 4 int16_t DpFilter_i vazaoPoco_i // changed in July 2023
// 5 int16_t Pinlet_i pumpStopTime // format=> 100* now.hour() + now.minute() March 2024
// 6 int16_t lampCurrent_i dummy4 //added in March 2021
// 7 int16_t rawDp rawDp
// Structure of our payload, limited to 32 bytes
struct payload_t // 32 bytes max, used= 4+7*2+1= 19 bytes OK! October 2024
int16_t val1; // - 2 bytes
int16_t val2; // - 2 bytes
int16_t val3; // - 2 bytes
int16_t val4; // - 2 bytes
int16_t val5; // - 2 bytes
int16_t val6; // - 2 bytes
payload_t payload; // create a variable with the above structure
//******** Initialize and define variables ***************
unsigned long startTime; //timer used to ckeck if data has been received
unsigned long clearTime = 90000; // in milliseconds
unsigned long waitTime = 60000; // in milliseconds
unsigned long pumpOnMillis =0; // time when pump has been turned ON
unsigned long pumpOnDelay = 10000; // wait 10 s to check if the flow has been established normally
unsigned long lastCisternaTime;
unsigned long lastCaixaTime;
unsigned long dataLossTime = 60000; // changed to 60 sec. Data is transmitted every second (Txtime in Cx & Cisterna) Jan 2024
unsigned long dataUpdateTime = 900; //Fev 2024 // each Tx is sending data every 1sec
const int LCDinterval = 5000; //added in rev noDelays (03/2021)
unsigned long buzzer_millis_new;
unsigned long buzzer_millis_old;
unsigned long fault_ID_mil[7];
unsigned long fault_ID_mil_Old[7] = { 0, 0, 0, 0, 0, 0, 0 };
bool flapState = LOW;
float Pdisch = 0.0;
float PdischLow = 0.5; // Check value !!!! ***** added in June 2021
float flow[3] = {0.0, 0.0 , 0.0};
float totalLiters_1 = 0.0;
float auxVol = 0.0;
float pumpFlowLow = 2.0; // ***Check Value info added June 2021
int rawDp[3] = {0, 0 , 0};
int rawDpMin = 32;
int rawDpMax[3] = {0, 243 , 187}; // values changed in rev 2_A
int levelDp[3] = {0, 0 , 0};
int levelDpLow = 30; // critical level in %
int levelDpMin = 20; // minimal level in %
int levelDpWarning = 50; // warning leval in %
int cisternaRxLossTime; // current time (in sec) when Cisterna RX loss happened
int caixaRxLossTime; // current time (in sec) when caixa RX loss happenend
int currentTime; // current time (in sec) of internal clock
float Irms = 0.0;
float current = 0.0;
float DpFilter = 0.0; // filter Dp in mmca
float DpFilter_max = 700.0; // was 600.0 changed in July 2023 (better display in Bar Graph)
float kFilter;
float Pinlet = 0.0;
float PinletLow = 1.0; // Changed in rev 3A- this variable has no useful purpose
float lampCurrent = 0.0;
float lampCurrentLow = 0.1;
//???float dummy1 = 0.0; changed to PumpStopTime Oct 2024
//???float dummy2 = 0.0; changed to dummy4 oct 2024
bool dummy3 = LOW;
int16_t dummy4 = 0;
uint32_t packetReceived[3] = {0,0,0}; // 1= cisterna, 2= caixa Jan 2024
uint32_t packetReceivedOld[3] = {0,0,0};
uint32_t nPacketsLost[3] = {0,0,0};
//---- define the new int16_t variables used for data transmission
//--caixa-----
int16_t auxVol_i;
int16_t totalLiters_1_i;
int16_t flow_i[3]; // used for cisterna also
int16_t pumpStopTime;
//--Cisterna
int16_t Irms_i;
int16_t Pdisch_i;
int16_t DpFilter_i;
int16_t Pinlet_i;
int16_t lampCurrent_i;
bool faultStatus = LOW;
bool warningStatus = LOW;
bool ackAlarmStatus = LOW;
bool delayRunning = LOW;
bool pump_State = LOW;
bool last_Pump_State = LOW;
bool flowDelay = LOW;
bool clearDataFlag = true; // Feb 2024 check if we will decide to clear the current values of buffers
bool cisternaRxLoss = false; // this is used to change text colour to yellow
bool caixaRxLoss = false;
bool buzzer_ON_OFF_Toggle = LOW; //is buzzer ON or OFF
bool buzzer_Status = LOW;
bool levelWarningStatus = LOW;
int x = 1;
unsigned long t1;
unsigned long t2;
//----FlowMin[]--------CHECK ACTUAL VALUES MEASURED BY THE FLOW SENSORS!!!-----------------
// average flowrate to reservoir 1 is 4.0 l/min --- let's set the alarm @ 50% of normal flowrate, so flowMin[1] = 2.0
// Calculated flowrate for the installed pump is 20 l/min --- let's set the alarm @ 50% of normal flowrate, so flowMin[2] = 10.0
float flowMin[3] = { 0.0 , 1.3 , 10.0 }; // minimum flow values used to trigger alarm condition // <=======Min flow changed to 1.3
//----Toggle button & Misc stuff----
int buzzerState=0;
int alarm_Button_New;
int alarm_Button_Old=1;
//???int ack_Button_New;
//???int ack_Button_Old=1;
int dt=100;
bool fault_ID[12] = {0,0,0,0,0,0,0,0,0,0,0,0 }; // revised March 2024
bool fault_ID_Old[12] = {0,0,0,0,0,0,0,0,0,0,0,0}; // revised March 2024
unsigned long fault_ID_millis[6] = {0,0,0,0,0,0};
unsigned long time_between_failures = 3600000;
int i= 1;
//------ Set s flag to define if Debug messages should be sent to Serial Port (active HIGH)
bool serialPrintFlag = HIGH; // <================================= Set DEBUG flag here
// Set a Flag to simulate that data is being received (active HIGH)
bool simulateInputData = LOW; // <================================ Use this to input data to the sketch
//------Define Pin numbers for buttons & LEDs
const int pump_On_Pin = 26;
const int alarm_On_Pin = 12;
const int alarm_Toggle_Button_Pin = 13;
const int ack_Alarm_Button_Pin = 33;
const int buzzerPin = 25;
const int fault_Led_Pin = 27;
const int warning_Led_Pin = 14;
//------Display without delay variables and definitions-------------------
unsigned long previousLCDMillis = 0; // for LCD screen update
unsigned long lcdInterval = 10000;
int screen = 0;
int screenMax = 2; //was 1 changed in July 2023
bool screenChanged = true; // initially we have a new screen, by definition
// defines of the screens to show
#define PROCESS_VARIABLES 0
#define DISPLAY_FAULTS 1
#define DRAW_GRAPH 2
// Define RCT variables added DEc 2022
float dummyTime;
int hVal;
int minVal;
// ------BarGraph variables and initial calculations--------
int valueBlock[4];
int posBlock[4];
int prevPosBlock[4];
uint16_t blockColor;
// Editable Variables
bool displayValues = true; // EDIT - Display Value of Blocks?
uint16_t graphColor = TFT_BLUE; // EDIT - Prefered Colour of Graph
//??? uint16_t blockColor = TFT_GREEN; // EDIT - Prefered Colour of Blocks <===== Bars can be green, yellow or red depending on value
String graphBlock[] = {"Cst", "Cx", "l/m", "DP" }; // EDIT - Names of Blocks
int graphRange = 100; // EDIT - Max possible number of block, eg Potentiometer = from 0 to 1024, so 1024 <==Changed to 100 (graphs in %)=======
int numberOfBlocks = 4; // EDIT - Number of Blocks to display
int dx= 52; // move x axis information to the right to correct display error
//-- calculate graph parameters-----
const int numberOfMarks = (numberOfBlocks * 2); // calculates amount of lines that mark x axis
const int originX = 52; // the origin of the graph on the x axis // Chosen value
const int originY = 280; // the origin of the graph on the y axis // ==> 320 (Height) -50 (for the Graph title) = 270
const int sizeX = 180; // the size of the chart on the x axis (lenght) // ==> 240 (width) - 60 (for the y axis value) = 180
const int sizeY = 230; // the size of the chart on the y axis (height) // ==> 320 (height) - 40 (for the Graph title) - 50 (for the Graph title) = 230
int boxSize = (sizeX / numberOfMarks); // calculates the size between the marks
int mark[] = {(dx+boxSize), (dx+boxSize * 2), (dx+boxSize * 3), (dx+boxSize * 4), (dx+boxSize * 5), (dx+boxSize * 6), (dx+boxSize * 7), (dx+boxSize * 8)}; // calculates the position of the marks
const int minorSizeY = (originY + 10); // calculates the y origin of the marks
const int minorSizeX = (originX - 10); // calculates the x origin of the numbers
//??? int numberSize = (sizeY / 6); // calculates the size between the numbers
//??? int number[] = {numberSize, (numberSize * 2), (numberSize * 3), (numberSize * 4), (numberSize * 5), (numberSize * 6)}; // calculates the position of the numbers
//??? int numberValue = (graphRange / 6); // calculates the value per number
//??? int val[] = {graphRange, (numberValue * 5), (numberValue * 4), (numberValue * 3), (numberValue * 2), numberValue}; // calculates the value of each number
// change y marks from 6 to 5
int numberSize = (sizeY / 5); // calculates the distance between each Y axis div
int number[] = {numberSize, (numberSize * 2), (numberSize * 3), (numberSize * 4),(numberSize * 5)}; // calculates the position of Y axis divisions
int numberValue = (graphRange / 5); // calculates the value of one Y axis div
int val[] = {graphRange, (numberValue * 4), (numberValue * 3), (numberValue * 2), numberValue}; // Y axis values
void setup() //-------------SETUP-------------------------------
// ----define Led pins as outputs
pinMode(alarm_On_Pin, OUTPUT);
pinMode(pump_On_Pin, OUTPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(alarm_Toggle_Button_Pin, INPUT_PULLUP);
pinMode(ack_Alarm_Button_Pin, INPUT_PULLUP);
pinMode(warning_Led_Pin, OUTPUT);
pinMode(fault_Led_Pin, OUTPUT);
// it seems that Arduino IDE does not define the pins as outputs so we do it manuallly here
pinMode(TFT_CS, OUTPUT);
digitalWrite(TFT_CS, HIGH);
pinMode(RF24_CSN, OUTPUT); // check if it is required
pinMode(RF24_CE, OUTPUT); // check if it is required
digitalWrite(RF24_CSN, HIGH); // check if it is required
//-----Start Serial Communication-------
Serial.begin(115200); // start serial communication
//-----Start TFT, set rotation and background color------
tft.init();
tft.setRotation(0);
tft.setTextSize(2);
// -----Start nRF24L01---------
SPI.begin();
radio.begin();
// check if nRF24L01 was initialized on SPI bus (ADDED Jan 2024)
if (!radio.begin()) {
if (serialPrintFlag == true) Serial.println(F("radio hardware is not responding!!"));
//??? tft.fillScreen(TFT_BLACK); // check if it is required
tft.println(F("radio not found"));
delay(2000);
//??? network.begin(channel, this_node); //Commented Jan 2024
radio.setPALevel(RF24_PA_HIGH); // Added Jan 2924 ??? Is it valid for an Rx?
radio.setDataRate( RF24_250KBPS ); //added on rev 3C
//########## we will open all pipes to see if we can find two that works #############
radio.openReadingPipe(1,addresses[0]); // All added on Feb 2024
radio.openReadingPipe(2,addresses[1]);
radio.openReadingPipe(3,addresses[2]);
radio.openReadingPipe(4,addresses[3]);
radio.openReadingPipe(5,addresses[4]);
radio.startListening(); //added on rev 3C
//------- Initialize display------------------ Welcome Message----------------------------------------
tft.setCursor(0, 0);
tft.setTextColor(ILI9341_YELLOW);
tft.setTextSize(3);
tft.println(F("2 pipes + Integer"));
tft.println(F(" "));
tft.println(F("22/09/2024"));
tft.println(F("rev 0"));
delay(2000);
// Check if data input is simulated and print warning message
if (simulateInputData == HIGH)
{ tft.setTextColor(ILI9341_RED);
tft.println(F("DATA READ SIMULATED"));
input_Data();
delay(2000);
// Set value for the timers monitoring Cisterna & Caixa data packets were received
startTime = millis(); // start the timer
lastCisternaTime = millis(); // start Cisterna RX timer
lastCaixaTime = millis(); // start Caixa RX timer
// For debugging radio info
if(serialPrintFlag == true){
printf_begin(); // needed only once for printing details
radio.printDetails(); // (smaller) function that prints raw register values
//???? radio.printPrettyDetails(); // (larger) function that prints human readable data // error compiling in laptop
} //------ this is the end of Setup
void loop() //-----------------LOOP------------------------------------
getRadioData();
// -------Calculate output variables from raw data ---------
levelDp[1] = map(rawDp[1], rawDpMin, rawDpMax[1], 0, 100);
levelDp[2] = map(rawDp[2], rawDpMin, rawDpMax[2], 0, 100);
kFilter = DpFilter / sq(flow[1]) ;
//------Light warning LEDs and Sound Buzzer--------------
Buzzer_and_Leds();
// -----Check if there are abnormal conditions in the system
check_faults();
//---Display data------
display_Data();
// sound buzzer if FAULT 7 had occured ---- Added REv 3A Dez 2021
if (buzzer_ON_OFF_Toggle ==HIGH && levelWarningStatus == HIGH)
beep_Buzzer();
} //-----------this is the end of the loop
// getRadioData // get data from transmitters
void getRadioData(){
if(radio.available(&pipeNum)){
radio.read(&payload,sizeof(payload));
if (pipeNum == 1){ // Changed Jan 2024 check pipe 1 => Cisterna
getCisternaData(); // Changed Jan 2024
if (pipeNum == 2){ // Changed Jan 2024 check pipe 2 => Caixa
getCaixaData(); // Changed Jan 2024
//--------node connection check----------------
// if the conn with one of the Txs is lost, lastCisternaTime and/or lastCisternaTime
// will NOT BE UPDATED so we can check this to detect a problem
//----Cisterna-----
if ( (millis() - lastCisternaTime) > dataLossTime){
cisternaRxLoss = true;
cisternaRxLossTime = millis()/1000;
if (serialPrintFlag == true){
Serial.print("******Cisterna Conn Failure***** ");
Serial.print(" time= ");
Serial.println(cisternaRxLossTime); // <====== Change his to the 1rst time when conn was lost
Serial.println("=== Clearing Cisterna Data ===");
clearCisternaData();
else { cisternaRxLoss = false;}
//----Caixa-----
if ( (millis() - lastCaixaTime) > dataLossTime){
caixaRxLoss = true;
caixaRxLossTime = millis()/1000 ;
Serial.print("******Caixa Conn Failure***** ");
Serial.println(caixaRxLossTime);
Serial.println("=== Clearing Caixa Data ===");
clearCaixaData();
else { caixaRxLoss = false;}
printSerial_1();
} // end getRadioData
// getCisternaData() // get data from Cisterna
void getCisternaData(){ //####MAJOR CHANGE IN 01/02/2024 ########
// tft.setTextColor(ILI9341_RED); // Commented Jan 2024
//------Read Cisterna Data-------
if(serialPrintFlag == true) Serial.println("------Reading Cisterna Data-----"); // <==================Reading Cisterna Data Message
packetReceived[1] = payload.counter;
//???? if( packetReceived[1] > packetReceivedOld[1] ){
// Check if connection is lost: Caixa data should be updated at last every 60 seconds
if ( (millis() - lastCisternaTime) > dataUpdateTime){
// this is new data
Serial.print("-- This is new Data---");
Serial.print(" Time= ");
Serial.println(millis());
// update Cisterna Data (ATTENTION!! ALL VALUES ARE INTEGERS NOW!!!
Irms_i = payload.val1;
flow_i[1] = payload.val2;
Pdisch_i = payload.val3;
DpFilter_i = payload.val4;
Pinlet_i = payload.val5;
lampCurrent_i = payload.val6;
rawDp[1] = payload.val7;
flapState = payload.val8;
// Convert integers to float values as in original code
Irms = Irms_i/10.0;
flow[1] = flow_i[1]/10.0;
Pdisch = Pdisch_i/10.0;
DpFilter = DpFilter_i/10.0;
Pinlet = Pinlet_i/10.0;
lampCurrent = lampCurrent_i/100.0; // this value is<1 so scale factor must be 100
// check how many packets were lost
nPacketsLost[1] = packetReceived[1]- packetReceivedOld[1] ;
lastCisternaTime = millis(); // restart the Cisterna RX timer
packetReceivedOld[1] = packetReceived[1];
clearDataFlag = false;
} // end of new data based on packet #
else { // some packages were lost!!!
nPacketsLost[2] = packetReceived[2]- packetReceivedOld[2] ;
Serial.print("-- WARNING NUMBER OF PACKETS LOST = ");
Serial.println(nPacketsLost[2]);
printCisternaData();
} // end getCisternaData
// getCaixaData() // get data from Caixa
void getCaixaData(){ //####MAJOR CHANGE IN 01/02/2024 ########
if (serialPrintFlag == true) { Serial.println("---------Reading Caixa Data--------");} //<==================Reading caixa Data Message
packetReceived[2] = payload.counter;
// Check if connection is lost: Caixa data should be updated at last every second
if ( (millis() - lastCaixaTime) > dataUpdateTime){
// this is new data
// update Caixa Data (ATTENTION!! ALL VALUES ARE INTEGERS NOW!!!
auxVol_i = payload.val1; // this is the batch volume
flow_i[2] = payload.val2;
totalLiters_1_i = payload.val3;
flow_i[0]= payload.val4; // Chaged in July 2023
pumpStopTime= payload.val5;
dummy4= payload.val6;
rawDp[2] = payload.val7;
dummy3 = payload.val8;
auxVol = auxVol_i/10.0;
flow[2] = flow_i[2]/10.0;
totalLiters_1 = totalLiters_1_i/10.0;
flow[0] = flow_i[0]/10.0;
pumpStopTime = pumpStopTime/10.0;
packetReceivedOld[2] = packetReceived[2];
lastCaixaTime = millis(); // restart the Caixa RX timer
caixaRxLoss = true;
//-------- for Debugging
printCaixaData();
} //--- end of getCaixaData
// Display Function
// MUST WE SWITCH SCREEN?
void display_Data()
unsigned long currentLCDMillis = millis();
if(currentLCDMillis - previousLCDMillis > lcdInterval) // save the last time you changed the display
previousLCDMillis = currentLCDMillis;
screen++;
if (screen > screenMax) screen = 0; // all screens done? => start over
// DISPLAY CURRENT SCREEN
if (screenChanged) // -- only update the screen if the screen is changed.
screenChanged = false; // reset for next iteration
switch(screen)
case PROCESS_VARIABLES:
display_variables();
case DISPLAY_FAULTS: // this screen should be displayed only if there are abnormal conditions
if (faultStatus == HIGH || warningStatus == HIGH) display_faults(); // changed March 2024
case DRAW_GRAPH:
drawGraph();
default:
// cannot happen -> showError() ?
} //--- end of display_data
// display Variables
void display_variables()
// return background to black (needed after displaying the bargraph) and set cursor
tft.fillScreen(TFT_BLACK); // moved from Cistena March 2024
tft.setTextSize(3);
tft.setTextColor(ILI9341_WHITE);
// customize output printing using node id for certain variables
// index 1 2
// place cisterna caixa
dummyTime = Pinlet;
hVal=floor(dummyTime/100.0);
minVal = dummyTime - 100.0*hVal;
if(serialPrintFlag == true) Serial.println("hVal= " + String(hVal) + " minVal= " + String(minVal) );
//***********CISTERNA***********
if (cisternaRxLoss == true) tft.setTextColor(ILI9341_YELLOW);
tft.println("* CISTERNA *");
tft.setTextSize(2);
tft.print("NIVEL= ");
tft.print(levelDp[1]);
tft.println(" %");
tft.print("l/min= ");
tft.println(flow[1]);
if (Irms !=0) // Pump is ON
tft.print ("CURR.= ");
tft.print (Irms, 1);
tft.println (" A");
digitalWrite(pump_On_Pin, HIGH);
else // Pimp is OFF
tft.println("Pump is OFF");
digitalWrite(pump_On_Pin, LOW);
tft.print("Flap ");
if (flapState == LOW) tft.println ("CLOSED");
else tft.println("OPEN");
tft.print("Pdisch= ");
tft.println(Pdisch);
tft.println (" ");
//??? tft.print("P_Inlet= ");
//??? tft.println(Pinlet);
tft.print("Dp Filter= ");
tft.println(DpFilter);
kFilter = DpFilter / sq(flow[1]) ; //-------Calculate Filter k ---------
tft.print("K Filter= ");
tft.println(kFilter);
tft.print("UV Lamp (A)= ");
tft.println(lampCurrent);
//********CAIXA**********************
tft.println (" ");
tft.setTextSize(3);
if (caixaRxLoss == true) tft.setTextColor(ILI9341_YELLOW);
tft.println("** CX. SUP **");
tft.setTextSize(2);
tft.print(levelDp[2]);
tft.println(" %");
tft.println(flow[2]);
tft.print("ult bomb(l)= ");
tft.println(auxVol);
tft.print("vaz Poço= ");
tft.println(flow[0]);
tft.print("Time= "); // <====== End of pumping cycle Dez 2022
tft.print(hVal);
tft.print(":");
if (minVal <10) tft.print("0");
tft.print(minVal);
} //---- end of display_variables
// Check Faults -- Identify possible faults in the system and turn alarm ON
void check_faults(){
faultStatus = LOW;
warningStatus = LOW; //-------------Added in Rev1 01/09/2019
// Start the pump cavitation/low flow check
pump_State = LOW;
// check if PUMP has been turned on and start flow delay timer
if (Irms > 0.0)
pump_State = HIGH;
if (pump_State == HIGH && last_Pump_State == LOW)
pumpOnMillis = millis();
last_Pump_State = HIGH;
flowDelay = HIGH;
if ((millis() - pumpOnMillis) > pumpOnDelay) flowDelay = LOW; // this is HIGH while waiting to purge air from pump discharge pipe
} // do this if pump is ON ONLY
else last_Pump_State = LOW;
//++++++++++++++++++++++++++++++++++Should be used for debug only+++++++++++++++++++++++++++
Serial.println ("---------------------------------Faults---------------------------------------");
Serial.println("checking pump State & Delay ");
Serial.println("FAULT 1 & 2----- Nivel Baixo nivel cisterna= " + String(levelDp[1]) + " nivel caixa= " + String(levelDp[2]));
Serial.println("FAULT 3----- vaz mininha vaz minima= " + String(flow[1]));
Serial.println("FAULT 4----- UV Failure Lamp Current= " + String(lampCurrent));
Serial.println("FAULT 5------Pump Protection Failure Irms " + String(Irms) + " Nivel Cisterna= " + String(levelDp[1]));
Serial.println("FAULT 6----- RF LINK LOSS Cisterna " +String(cisternaRxLoss) + " Caixa " + String(caixaRxLoss));
Serial.println("-----------------------------------Warnings-----------------------------------");
Serial.println("fault 7------Check Level nivel cisterna= " + String(levelDp[1]) + " nivel caixa= " + String(levelDp[2]));
Serial.println("fault 8------High Filter DP Filter DP= " + String(DpFilter));
Serial.println("fault 9------No Flow with Pump ON Irms= " + String(Irms) + " pumpOnMills= " + String(pumpOnMillis) + " flowDelay= "+ String(flowDelay));
Serial.println("flaut 10-----Flap closed & pump ON Irms= " + String(Irms) + " flapState= " + String(flapState));
// FAULT 1 --- low level in reservoir 1 (Cisterna)
if ( levelDp[1] < levelDpLow) {
faultStatus = HIGH;
fault_ID[1] = HIGH;
else {
faultStatus = LOW;
fault_ID[1] = LOW;
// FAULT 2 --- Low level in reservoir 2 (Caixa)
if (levelDp[2] < levelDpLow ) {
faultStatus = HIGH;
fault_ID[2] = HIGH;
else {
faultStatus = LOW;
fault_ID[2] = LOW;
// FAULT 3 --- Low flow to reservoir 1 (Cisterna)
if ( flow[1] <= flowMin[1] ){
faultStatus = HIGH;
fault_ID[3] = HIGH;
else {
faultStatus = LOW;
fault_ID[3] = LOW;
// FAULT 4--- UV Lamp Current too low
if ( lampCurrent < lampCurrentLow ){
faultStatus = HIGH;
fault_ID[4] = HIGH;
else {
faultStatus = LOW;
fault_ID[4] = LOW;
// FAULT 5 -- Pump on with low level in reservoir 1
if ( Irms > 0.0 && levelDp[1] <= levelDpMin) {
faultStatus = HIGH;
fault_ID[5] = HIGH;
else {
faultStatus = LOW;
fault_ID[5] = LOW;
// FAULT 6 ---RF Link Loss //Added in June 2021
if ( caixaRxLoss == HIGH || cisternaRxLoss == HIGH )
faultStatus = HIGH;
fault_ID[6] = HIGH;
else {
faultStatus = LOW;
fault_ID[6] = LOW;
// -----This is the beginning of the warnings section-------------------------------
// FAULT 7 -- Level in Reservoirs 1 or 2 below normal
if ( levelDp[1] <= levelDpWarning || levelDp[2] <= levelDpWarning)
if ( fault_ID[1] == LOW && fault_ID[2] == LOW ) // check if the levels are NOT in the VERY LOW condition to set Warning
warningStatus = HIGH;
levelWarningStatus = HIGH;
fault_ID[7] = HIGH;
else {
fault_ID[7] = LOW;
//FAULT 8 -- Pressure drop very high in Filter
if ( DpFilter > DpFilter_max ){
fault_ID[8] = HIGH;
else {
fault_ID[8] = LOW;
// FAULT 9 -- low or no flow (after 60 sec) with pump on
if (Irms > 0.0 && flowDelay == LOW && flow[2] <= flowMin[2]){
fault_ID[9] = HIGH;
else {
fault_ID[9] = LOW;
// FAULT 10 -- Flap closed with pump ON
if ( Irms > 0.0 && flapState == LOW){
fault_ID[10] = HIGH;
else {
fault_ID[10] = LOW;
// FAULT 11 (old definition) --- Filter Inlet Pressure too low (air in pipe)
// ----This Warning was delete since it makes no sense
// FAULT 11 (New definition) -- Pump Cavitation ( Pump ON AND (low Pdisch OR low flow to reservoir 2 )
//--- first implementation in JUNE 2021--- check if works before adding to critical faults
if ( Irms > 0.5 && ( Pdisch <= PdischLow || flow[2] <= pumpFlowLow )) {
fault_ID[11] = HIGH;
else {
fault_ID[11] = LOW;
// --- Check if there are faults and/or warnings and turn ON the corresponding LEDs
if( warningStatus == HIGH ) digitalWrite(warning_Led_Pin, HIGH);
else digitalWrite(warning_Led_Pin, LOW);
if( faultStatus == HIGH) digitalWrite(fault_Led_Pin, HIGH);
else digitalWrite(fault_Led_Pin, LOW);
Serial.println ("---------------------------Fault Status Indicators-------------------------");
Serial.println ("faultStatus= " +String(faultStatus));
Serial.println ("warningStatus= " +String(warningStatus));
} // ----- end of check faults
// Display Faults -- Display the faults in the system
void display_faults(){
// Prepare display to show faults
tft.fillScreen(ILI9341_BLACK);
tft.setCursor(0 ,0);
tft.setTextColor(ILI9341_RED); tft.setTextSize(2);
//RF link loss is the most critical fault so other faults related to zero value variables makes no sense
// So this will be the first fault to be checked
if (fault_ID[6] == HIGH){
if ( caixaRxLoss == HIGH ){
tft.println("**CAIXA LINK LOSS**");
tft.print(" time= ");
tft.println(caixaRxLossTime);
tft.print(" currentTime= ");
currentTime=millis()/1000;
tft.println(currentTime);
tft.println(" ");
if ( cisternaRxLoss ==HIGH ){
tft.println("***CIST LINK LOSS***");
tft.println(cisternaRxLossTime);
tft.println(" ");
if (fault_ID[1] == HIGH){
tft.println("VERY LOW LEVEL IN");
tft.print("Cisterna = ");
tft.println(" %");
tft.println(" ");
if (fault_ID[2] == HIGH){
tft.print("Caixa Sup = ");
tft.println(levelDp[2]);
tft.println(" %");
tft.println(" ");
if (fault_ID[3] == HIGH){
tft.println("LOW FLOW TO CISTERNA");
tft.print("Flow(l/m) = ");
tft.println (flow[1]);
tft.println(" ");
if (fault_ID[4] == HIGH){
tft.println("LOW UV LAMP CURRENT");
tft.print("lampCurrent = ");
tft.print (lampCurrent);
tft.println(" A");
tft.println(" ");
if (fault_ID[5] == HIGH){
tft.println("PUMP PROTECTION FAILURE");
tft.print("level = ");
tft.println(" %");
tft.println(" ");
// Change Text colour to yellow
if (fault_ID[7] == HIGH){
tft.println("CHECK LEVEL");
if (levelDp[1] <= levelDpWarning)
tft.print("Cisterna= ");
tft.println(" %");
if (levelDp[2] <= levelDpWarning)
tft.print("Caixa= ");
tft.println(" %");
tft.println(" ");
if (fault_ID[8] == HIGH){
tft.println("HIGH FILTER DP");
tft.print("DpFilter = ");
tft.println (DpFilter);
tft.println(" ");
if (fault_ID[9] == HIGH){
tft.println("PUMP LOW FLOW FAIL");
tft.print("Flow(l/min) = ");
tft.println(" ");
if (fault_ID[10] == HIGH){
tft.println("FLAP CLOSED FAILURE");
tft.print("Current= ");
tft.print(Irms, 1);
tft.println(" A");
tft.println(" ");
if (fault_ID[11] == HIGH){
tft.println("PUMP CAVITATION");
tft.print("Pdisch = ");
tft.println (Pdisch);
tft.print("Vazao(l/m) = ");
tft.println (flow[2]);
tft.println(" ");
/* // NO NEED TO PRINT THIS MESSAGE AFTER THE BARGRAPH IMPLEMENTATION
// Changed in the July 2023 Rev - no need to Clear screen, just display the "no faults detected" message
//If no faults were detected, print message
if (faultStatus == LOW && warningStatus == LOW) {
//??? tft.fillScreen(ILI9341_BLACK); //commented out in July 2023
tft.setCursor(4, 0); // changed July 2023
tft.setTextColor(ILI9341_GREEN); tft.setTextSize(3);
tft.println("NO FAULTS");
tft.println("DETECTED");
delay(1000); // Added in Rev 3C ***Check if it is required
} //--- end of display_faults()
// beep_Buzzer
void beep_Buzzer(){
t2=millis();
if (t2-t1 >=2000)
x=1-x;
t1=millis();
digitalWrite(buzzerPin,x);
if (serialPrintFlag == true)Serial.println ("millis= " +String(millis())+ " x= " + String(x));
// input_Data()
// &&&&& USE FOR DEBUGGING ONLY &&&&&&&&&&
// Use this fuction to input data to the receiver to test code
void input_Data(){
Serial.println(" Simulating Operation ");
tft.setTextSize(3);
tft.print("Simulating Operation");
delay (1000);
// Values that will be used as received
//------Cisterna------------
Serial.println(" Cisterna Data ");
Irms = 0.0; // Pump OFF
flow[1] = 2.0; // Normal Contition
Pdisch = 2.6; // Pump OFF
DpFilter = 100.0; // Norm =100, max= 600
Pinlet = 856.0; // This variable is used for time. Value = 100*hour + minutes
lampCurrent = 0.17; // Lamp ON
rawDp[1] = 200; // Normal Operation (Max=243 , warrning=50%, Low=30%, min= 20%)
flapState = HIGH; // Pump OFF
cisternaRxLoss = LOW; // Cisterna RF Link OK
//-------Caixa-------------
Serial.println(" Caixa Data");
auxVol = 0.0; // Not used for alarms ==>his is the batch volume
flow[2] = 2.1; // min= 2.0
totalLiters_1 = 0.0; // Not used for alarms
flow[0]= 7.6; // Added in July 2023 (vazao do poço)
pumpStopTime= 0.0; // Not used for alarms
dummy4= 0; // Not used for alarms
rawDp[2] = 170; // Normal Operation (Max=187 , warrning=50%, Low=30%, min= 20%)
dummy3 = LOW;
caixaRxLoss = LOW; // Caixa RF Link OK
//??? clearDataFlag = false; // check if required
// Print values used in this simulation
Serial.println ("clearDataFlag= " + String(clearDataFlag));
Serial.println ("levelDp[1]= " + String(levelDp[1]));
Serial.println ("levelDp[2]= " + String(Irms));
Serial.println ("Irms= " + String(Irms));
Serial.println ("rawDp[1]= " + String(rawDp[1]));
Serial.println ("Pdisch= " + String(Pdisch));
Serial.println ("DpFilter= " + String(DpFilter));
Serial.println ("Pinlet= " + String(Pinlet));
Serial.println ("kFilter= " + String(kFilter));
Serial.println ("auxVol= " + String(auxVol));
Serial.println ("flow[2]= " + String(flow[2]));
Serial.println ("totalLiters_1= " + String(totalLiters_1));
Serial.println ("lampCurrent= " + String(lampCurrent));
} // This is the end of input_Data
// Buzzer_and_Leds()
//-----------Check buttons, Light Led's & sound buzzer when required
void Buzzer_and_Leds(){
// Toggle BUZZER ON/OFF and display LED status accordingly
alarm_Button_New = digitalRead(alarm_Toggle_Button_Pin);
if(alarm_Button_Old == 0 && alarm_Button_New == 1)
if (buzzer_ON_OFF_Toggle == LOW)
digitalWrite(alarm_On_Pin,HIGH);
buzzer_ON_OFF_Toggle = HIGH;
tft.fillScreen(ILI9341_BLACK); // used in test alarm
tft.setTextColor(ILI9341_RED); tft.setTextSize(3);
tft.println("BUZZER IS ON");
digitalWrite(alarm_On_Pin, LOW);
tft.println("BUZZER IS OFF");
alarm_Button_Old=alarm_Button_New;
delay(dt);
} // this is the end of buzzer & LEDs function
// drawGraph()
void drawGraph()
// initial definitions
tft.init();
tft.setRotation(0);
tft.fillScreen(TFT_WHITE);
// draw title
tft.setCursor(10, 10);
tft.setTextColor(TFT_BLUE);
tft.setTextSize(2);
tft.println(F("Lvls,Flow & DP (%)"));
tft.print(F("l/m= "));
tft.print(flow[1]);
tft.print(F(" DP= "));
// draw outline
tft.drawLine(originX, originY, (originX + sizeX), originY, graphColor);
tft.drawLine(originX, originY, originX, (originY - sizeY), graphColor);
// draw lables
for(int i = 0; i < numberOfMarks; i++)
tft.drawLine(mark[i], originY, mark[i], minorSizeY, graphColor);
// draw label names
for(int i = 0; i < numberOfMarks; i += 2)
tft.setCursor((mark[i] + 6), (originY + 10));
tft.setTextColor(graphColor);
tft.setTextSize(2);
tft.println(graphBlock[i / 2]);
// draw numbers
for(int i = 0; i < 5; i++) // was 6
tft.drawLine(originX, (originY - number[i]), minorSizeX, (originY - number[i]), graphColor);
// draw values of Y axis marks
// for some reason numbers are in the wrong position
//let's add a "correction offset" as was done in the X axis
int dy =-46; // worked!
tft.setCursor((minorSizeX - 30), (number[i] + numberSize +dy));
tft.setTextSize(1);
tft.println(val[i]);
// get the values of the sensors <========== COMMENT THIS SECTION AFTER TESTING=================================
valueBlock[0] = map(analogRead(A14),0,1024,0,100);
valueBlock[1] = map(analogRead(A15),0,1024,0,100);
valueBlock[2] = map(analogRead(A14),0,1024,0,100);
valueBlock[3] = map(analogRead(A15),0,1024,0,100);
// get the value of the variables to be displayed
valueBlock[0] = levelDp[1];
valueBlock[1] = levelDp[2];
valueBlock[2] = map(flow[1],0,6,0,100); // Assumed max lowrate = 6.0 l/min
valueBlock[3] = map(DpFilter,0,700,0,100); // Assumed Dp_max= 700 mmH2O
// map the sensor values to the graph size
for(int i = 0; i < numberOfBlocks; i++)
posBlock[i] = map(valueBlock[i], 0, graphRange, originY, (originY - sizeY));
// draw the blocks - draw only if value differs and select colour <===== This was changed
// The blocks need to be drawn ALWAYS
//??? if(posBlock[i] > (prevPosBlock[i] + 2) || posBlock[i] < (prevPosBlock[i] - 2))
prevPosBlock[i] = posBlock[i];
tft.fillRect((mark[i * 2] + 1), (originY - sizeY), (boxSize - 1), sizeY, TFT_WHITE);
// for levels and flow, low values should be RED for Filter DP high values are RED and low values are GREEN
if (i<=2)
if ( valueBlock[i] >= 50 ) blockColor = TFT_GREEN;
if ( valueBlock[i] < 50 && posBlock[i] >= 30) blockColor = TFT_YELLOW;
if (valueBlock[i] < 30 ) blockColor = TFT_RED;
if ( valueBlock[i] >= 50 ) blockColor = TFT_RED;
if (valueBlock[i] < 30 ) blockColor = TFT_GREEN;
tft.fillRect((mark[i * 2] + 1), posBlock[i], (boxSize - 1), (originY - posBlock[i]), blockColor);
// display values of sensors if mode selected
if(displayValues)
tft.setCursor((mark[i] + 5), (originY - 20));
tft.setTextColor(TFT_BLACK, TFT_WHITE); // changed
tft.setTextSize(2);
tft.println(valueBlock[i / 2]);
} // --- end of drawGraph
// THIS FUNCTION WAS USED DURING THE DEVELOPMENT OF THE CODE AND NO LONGER IS REQUIRED
// checkPipe -------- check if there is data available in a pipe and read it
// source: https://raspberrypi.stackexchange.com/questions/37033/nrf24l01-multiple-transmitters-one-receiver
void checkPipe()
//??? uint8_t pipeNum; //<-------- moved to global variable
Serial.print("Got data on pipe= ");
Serial.println(pipeNum);
// printSerial_1 -------- check if there is data available in a pipe and read it
void printSerial_1()
Serial.print("---------getting radio data from pipe= ");
Serial.print(pipeNum);
Serial.println(" -----------------------");
Serial.print("----time = ");
Serial.print("val0= ");
Serial.println(payload.counter);
Serial.print("val1= ");
Serial.println(payload.val1);
Serial.print(" val2= ");
Serial.println(payload.val2);
Serial.print(" val3= ");
Serial.println(payload.val3);
Serial.print(" val4= ");
Serial.println(payload.val4);
Serial.print(" val5= ");
Serial.println(payload.val5);
Serial.print(" val6= ");
Serial.println(payload.val6);
Serial.print(" val7= ");
Serial.println(payload.val7);
Serial.print(" val8= ");
Serial.println(payload.val8);
// printCisternaData -------- check if there is data available in a pipe and read it
void printCisternaData()
Serial.println("----------Cisterna Data----------- ");
Serial.print("packetReceivedOld[1]= ");
Serial.println(packetReceivedOld[1]);
Serial.print("packetReceived[1]= ");
Serial.println(packetReceived[1]);
Serial.print("nPacketsLost[1]= ");
Serial.println(nPacketsLost[1]);
Serial.print("cisternaRxLoss ");
Serial.println(cisternaRxLoss);
Serial.print(" millis= ");
Serial.print(" lastCisternaTime= ");
Serial.println(lastCisternaTime);
void printCaixaData()
Serial.println("-------Caixa Data------- ");
Serial.print("packetReceivedOld[2]= ");
Serial.println(packetReceivedOld[2]);
Serial.print("packetReceived[2]= ");
Serial.println(packetReceived[2]);
Serial.print("nPacketsLost[2]= ");
Serial.print("caixaRxLoss ");
Serial.println(caixaRxLoss);
Serial.print(" lastCaixaTime= ");
Serial.println(lastCaixaTime);
// clearCisternaData() used to clear data in case of communication failure with Cistena node
void clearCisternaData()
Irms = 0.0;
flow[1] = 0.0;
Pdisch = 0.0;
DpFilter = 0.0;
Pinlet = 0.0;
lampCurrent = 0.0;
rawDp[1] = 0;
flapState = LOW;
hVal = 0;
minVal = 0;
// clearCaixaData() used to clear data in case of communication failure with caixa node
void clearCaixaData()
auxVol = 0.0;
flow[2] = 0.0;
flow[0]= 0.0;
pumpStopTime= 0.0;
dummy4= 0;
rawDp[2] = 0;
dummy3 = LOW;
