ESP32 SPI issues
Hello, i am struggling with a spi connection between a ESP32-S3-DevKitC-1 (Master) and a ESP32 C3 Super Mini (Slave)
My Code:
#include <Arduino.h>
#include <SPI.h>
#define SCLK  4
#define MISO  5
#define MOSI  6
#define SS    7
  pinMode(SS, OUTPUT);
  SPI.begin(SCLK, MISO, MOSI, SS);
  SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
  digitalWrite(SS, LOW);
  byte dataToSend = 0x42;
  byte receivedData = SPI.transfer(dataToSend);
  digitalWrite(SS, HIGH);
#include <SPI.h>
#define SCLK  4
#define MISO  5
#define MOSI  6
#define SS    7
volatile byte receivedData;
volatile bool dataReceived = false;
  pinMode(SS, INPUT_PULLUP);
  pinMode(MISO, OUTPUT);
  if(digitalRead(SS) == LOW)
    receivedData = SPI.transfer(0x00);
    Serial.print("receives data: ");
    Serial.println(receivedData, HEX);
I tried it in ArduinoIDE with the boards selected:
"ESP32S3 Dev Module" and "Nologo ESP32C3 Super Mini"
in the Serial Terminal i just receive 0
I also tried it in Visual Studio Code with the Platformio extension, i selected:
"esp32-s3-devkitc-1" and "seeed_xiao_esp32c3"
i got the same result
i connected the grounds and pins 4-7 together on the boards.
would be nice if someone could help me.
Pinout Top
Please, post the pictures of your above two boards along with SPI connection to allow me running your codes.
I can not understand what you are doing hardware wise, it sounds like you are trying to connect two boards at the same time. Post a photo that clearly shows the wiring connections (may need 4 or 5)
i made a mistake i meen pins 4-7 i just corrected it.
