SPI on ESP32 doesnt get data
I have two Esp32S3 boards, and I want to establish Spi communication between them. I have a couple of questions:
  1. Why can't I see the clock signal using the logger?
  2. Why can't I receive the data?
#include <SPI.h>
#define MOSI_PIN 10
#define MISO_PIN 9
#define SCK_PIN  8
#define SS_PIN   5
SPIClass hspi;
  hspi.begin(SCK_PIN, MISO_PIN, MOSI_PIN, SS_PIN);
  pinMode(SS_PIN, OUTPUT);
  digitalWrite(SS_PIN, HIGH);
  Serial.println("L Start..");
  digitalWrite(SS_PIN, LOW);
  hspi.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
  hspi.transfer(0xFA);
  hspi.endTransaction();
#include <SPI.h>
#define MOSI_PIN 10
#define MISO_PIN 9
#define SCK_PIN  8
#define SS_PIN   5
  pinMode(SS_PIN, INPUT_PULLUP);
  SPI.begin(SCK_PIN, MISO_PIN, MOSI_PIN, SS_PIN);
  if (digitalRead(SS_PIN) == HIGH)
    byte receivedData = SPI.transfer(0x00);
    Serial.print("Data Received: ");
    Serial.println(receivedData, HEX);
Ive never done it myself but i believe theres an spi.attachslave method
SPI works in a master slave idea. 1 master, many slaves
Im assuming running 2 masters your clock signals will be colliding.
Well the pins you are trying to use for SPI are also used for the flash, you can't use those pins.
#define MOSI_PIN 10
#define MISO_PIN 9
#define SCK_PIN  8
Try different pins, and also you method for using hspi is not correct.
either use a global pointer
SPIClass * hspi = NULL;
setup() {
hspi = new SPIClass(HSPI);
hspi->begin(SCK_PIN, MISO_PIN, MOSI_PIN, SS_PIN);
or define which SPI to use when declaring
SPIClass hspi(HSPI);
setup() {
But mainly, use different pins, not 6 - 11 and i found even pins 12 & 13 to be problematic.
