ESP32 to DC Motor Control — Need Assistance
Hi all,
I’m very new to the Arduino/ESP32 space and was hoping to get some help. I’ve been working on a simple project using an ESP32 board and an L298 motor controller to drive a 12V DC motor.
I’ve confirmed that all of my hardware components should be functioning properly, so I suspect the issue may be related to my code or possibly a wiring mistake. Any help would be greatly appreciated—I’ve been stuck on this for weeks.
Here’s the code I’m currently using:
// Motor control pins
#define ENA 14
#define IN1 27
#define IN2 26
// Pin setups
  pinMode(ENA, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  Serial.println("Motors now waiting...");
digitalWrite(ENA, 25);
digitalWrite(IN1, HIGH); // control motor direction
digitalWrite(IN2, LOW); // control motor direction
delay(10);
Welcome!
The L298 motor controller is an obsolete part, it gets hot as it drops about 1.5Volts per lead so a 12V supply will give you about 9 Volts on the motor.
Your description is misleading, your batteries will be about 3.7 for normal operation and in series that gives you 7.4 volts, a lot less then thee implied 12V. Now subtract 3V for the L298 leaving 4.4 volts
I cannot tell from your not to clear picture how you have wired this. It would be a big help if you posted an annotated schematic showing exactly how it is wired and also show the power sources and links to each of the hardware devices.
Hi! Welcome to the Forum.
+1 to
The module that is shown on the pic is not a L298, although some dealer sites like Aliexpress call it like this. Google Lens pointed me out to the XY160D, a DRV-1011 mosfet based board.
7A-160W motor control Spec Sheet.pdf (760,6,KB)
25 is probably too low for the motor to start, specially after this observation:
try it at full 255
That should be an analogWrite(ENA, 255) and as @Brazilino pointed out try 255
Which ESP are you using?
should be analogWrite(255) or digitalWrite(1) but digitalWrite(25) does the same thing
i've never seen a motor board like that, with external mosfets. Can you list the labels on the header. Presumably there should be a IN0, IN1 and EN pins for 2 motors
what is the part/model # for the driver board?
Yes, exactly!
PDF of the possible datasheet is at post #3 (I don’t know if the board that OP has is from that manufacturer)
is the motor connected to the correct connector for IN0/1 and ENA. Looks like these pins for the bottom connector.
Another good catch
Thanks everyone for the help and the suggestions. I made the recommended change to the analogWrite part, and I also tried switching from the ESP32 to an Arduino Uno R4 using the same code. With the Uno, it worked perfectly, which makes me think the issue was with my wiring on the ESP32 side, maybe something with the 5V pins.
int ENA = 9;
int IN1 = 8;
int IN2 = 7;
int ENAB = 11;
int IN3 = 13;
int IN4 = 12;
// Pin setups
  pinMode(ENAB, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
Serial.println("Motors now running...");
digitalWrite(IN3, LOW); // control motor direction
digitalWrite(IN4, HIGH); // control motor direction
analogWrite(ENA, 100);
analogWrite(ENAB, 100);
delay(10);
My goal is to control this project with a PS4 controller instead of hard-coding the motor movement, so I’d like to understand why the ESP32 setup didn’t work. Any guidance is appreciated.
For reference, here’s how I had the ESP32 connected to the motor driver:
5V+ → 5V
ENA → pin 14
IN1 → pin 27
IN2 → pin 26
GND → GND
This is the correct motor driver diagram to refer to as well. the specific esp32 board I am using is this one " HiLetgo ESP-WROOM-32 ESP32 ESP-32S" :
You have uncommon driver. Quite likely it has to be supplied at ESP32 logic level voltage.
So connect Esp32 3.3V pin to driver 5V pin.
Well that is not what you show in your code.
So how do you actually have it connected?
You will probably need a level shifter that can supply enough current to drive the driver inputs.
Still need help?
