I would like to ask what is wrong with this expression? [[server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/html", index_html, processor);
});]] The translation always stops with an error for me.
- It's not posted in the context of a complete code.
- It's not correctly posted using Code Tags.
Thanks for the comment. I'm currently learning how the web server works and I wanted to try an example program. esp32 ds18b20 telemetry. I'll also copy the program itself, which is from this url.(((( ESP32 DS18B20 Temperature Sensor with Arduino IDE (Single, Multiple, Web Server) | Random Nerd Tutorials )))))
Rui Santos & Sara Santos - Random Nerd Tutorials
Complete project details at https://RandomNerdTutorials.com
// Import required libraries
#ifdef ESP32
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#else
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Hash.h>
#include <ESPAsyncTCP.h>
#endif
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is connected to GPIO 4
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
// Variables to store temperature values
String temperatureF = "";
String temperatureC = "";
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readDSTemperatureC() {
// Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
sensors.requestTemperatures();
float tempC = sensors.getTempCByIndex(0);
if(tempC == -127.00) {
Serial.println("Failed to read from DS18B20 sensor");
return "--";
Serial.print("Temperature Celsius: ");
Serial.println(tempC);
return String(tempC);
String readDSTemperatureF() {
float tempF = sensors.getTempFByIndex(0);
if(int(tempF) == -196){
return "--";
Serial.print("Temperature Fahrenheit: ");
Serial.println(tempF);
return String(tempF);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<style>
html {
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 3.0rem; }
.units { font-size: 1.2rem; }
.ds-labels{
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>ESP DS18B20 Server</h2>
<p>
<i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
<span class="ds-labels">Temperature Celsius</span>
<span id="temperaturec">%TEMPERATUREC%</span>
<sup class="units">°C</sup>
</p>
<p>
<span class="ds-labels">Temperature Fahrenheit</span>
<span id="temperaturef">%TEMPERATUREF%</span>
<sup class="units">°F</sup>
</p>
</body>
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperaturec").innerHTML = this.responseText;
xhttp.open("GET", "/temperaturec", true);
xhttp.send();
}, 10000) ;
document.getElementById("temperaturef").innerHTML = this.responseText;
xhttp.open("GET", "/temperaturef", true);
xhttp.send();
}, 10000) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DS18B20 values
String processor(const String& var){
//Serial.println(var);
if(var == "TEMPERATUREC"){
return temperatureC;
else if(var == "TEMPERATUREF"){
return temperatureF;
return String();
void setup(){
// Serial port for debugging purposes
// Start up the DS18B20 library
sensors.begin();
temperatureC = readDSTemperatureC();
temperatureF = readDSTemperatureF();
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi");
Serial.print(".");
// Print ESP Local IP Address
// Route for root / web page
request->send_P(200, "text/html", index_html, processor);
server.on("/temperaturec", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temperatureC.c_str());
server.on("/temperaturef", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temperatureF.c_str());
// Start server
server.begin();
void loop(){
if ((millis() - lastTime) > timerDelay) {
lastTime = millis();
And this is the error message:
/home/willmenn/Arduino/libraries/ESPAsyncWebServer/src/WebAuthentication.cpp: In function 'bool getMD5(uint8_t*, uint16_t, char*)':
/home/willmenn/Arduino/libraries/ESPAsyncWebServer/src/WebAuthentication.cpp:74:3: error: 'mbedtls_md5_starts_ret' was not declared in this scope; did you mean 'mbedtls_md5_starts'?
74 | mbedtls_md5_starts_ret(&_ctx);
| mbedtls_md5_starts
/home/willmenn/Arduino/libraries/ESPAsyncWebServer/src/WebAuthentication.cpp:75:3: error: 'mbedtls_md5_update_ret' was not declared in this scope; did you mean 'mbedtls_md5_update'?
75 | mbedtls_md5_update_ret(&_ctx, data, len);
| mbedtls_md5_update
/home/willmenn/Arduino/libraries/ESPAsyncWebServer/src/WebAuthentication.cpp:76:3: error: 'mbedtls_md5_finish_ret' was not declared in this scope; did you mean 'mbedtls_md5_finish'?
76 | mbedtls_md5_finish_ret(&_ctx, _buf);
| mbedtls_md5_finish
Multiple libraries were found for "ESPAsyncWebServer.h"
Used: /home/willmenn/Arduino/libraries/ESPAsyncWebServer
Not used: /home/willmenn/Arduino/libraries/ESP_Async_Web_Server
Not used: /home/willmenn/Arduino/libraries/ESP_Async_WebServer
exit status 1
Compilation error: exit status 1
Getting ESP32 examples from the Web to work is notoriously difficult because both the ESP32 Arduino Platform and supporting ESP-specific libraries change so frequently. Many times, the changes break code written using previous versions. Random Nerd Tutorials is generally pretty good but still suffers from this problem.
If you want to follow their code verbatim, I’d recommend using the exact same version of ESP32 Arduino Platform and ALL libraries that they did. You also should build up the code from the early examples in the tutorial making sure everything works before moving to the next. Don’t just jump to the final code expecting it to work right out of the box.
This is also suspicious:
Finally, I note that the compiler error messages that you just posted don't match your question from your original post.
Thanks for the answer!
The error message did indeed change, but I reinstalled the arduino ide in the meantime, and as you wrote, it may have used a different library.
Thanks for the tip!
I actually downloaded the libraries you indicated, and everything worked fine. As I said, I'm just starting to delve into it, but I never thought that libraries with the same name could be so different!
