Esp32 uses
Hello All, I think I may have taken a wrong turn with ordering the ESP32 with camera believing that it was a camera module that would work with a MKRGSM1400. I didn't realise that this is a controller in its own right
I wanted something that would snap a photo upon an event triggering (this is my ultrasonic alarm from the programming section)
So my question is can the esp32 “module” be used as a camera connected to the mkrgsm1400 so that it stores a photo to SD card or should I be looking for another anther camera module if there is one?
I have looked all over the web for an answer but cannot find anything specific
Thanks in advance
Dan
In the absence of any details (hint), I guess your ESP32 module doesn't have an SD card slot.
It has an SD slot, what I am asking is can it be used as a module to take photos when the mkrgsm1400 triggers
I am not interested in using it asa micro-controller or wifi etc inthis project, i just needsome module to take and store photos following an event
Thanks
Dan
The ESP32 should have plenty of unused I/O, so yes, it should be capable of being triggered by another device.
Thanks for the reply
Has anyone actually used it this way?
I think subconsciously you wanted a wireless camera :grin: :smiley: :stuck_out_tongue:
if you take the ESP32 and the camera
add a button
press the button, take a picture.
then you proved how it works.
connect the MKRGSM1400, to the ESP32, digital pin to digital pin
send out a signal from the MKRGSM1400 to the ESP32, it will act just like you pressed the button.
did you want to get that picture over to the MKRGSM1400 ?
as HutKikz mentioned you can buy a wiresless gsm pir camera , cheap, low res for $20
I will have a go at this, thanks. I dint want a separate pir camera, thats too easy
