Esp32 with rfid module to do multiple nested if statements
Hi!
I am working on a project to do a kind of automated fare collection system. I interfaced a RFID(MFRC-522) module with ESP32 and trying to do multiple if statements 1 after 1...
#include <ETH.h>
#include <WiFi.h>
#include <WiFiAP.h>
#include <WiFiSTA.h>
#include <WiFiUdp.h>
#include <WiFiScan.h>
#include <WiFiType.h>
#include <WiFiMulti.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <HTTPClient.h>
#include <WiFiGeneric.h>
#include <BluetoothSerial.h>
#include <SPI.h>
#include <HCSR04.h>
#include <MFRC522.h>
#include <AsyncTCP.h>
#include <Adafruit_MQTT.h>
#include <AsyncElegantOTA.h>
#include <ESPAsyncWebServer.h>
#include <Adafruit_MQTT_Client.h>
String User_A = "00 0S 00 0S";
String User_B = "01 0S 01 0S";
String User_C = "E7 72 8A 7B";
#define BDT                 " BDT."
#define Message_I           "QR code invalid."
#define Message_G           "Welcome to Bangladesh Road Transportation AFC System."
#define Message_B           "Please place your user card in front of the scanner..."
#define Message_U           "User card tapped at bus : "
#define Message_A           "Available balance : "
#define Message_C           "Your current balance : "
#define Message_Y           "Please recharge your card!"
#define Message_T           "You do not have the required amount to travel with us."
#define Message_F           "Thank you for choosing us!"
#define Safety_Measurement  "Stay Safe.Stay Healthy."
int trigPIN = 17;
int echoPIN = 21;
UltraSonicDistanceSensor ultrasonicSensor(trigPIN,echoPIN);
String Uttara            = "10 1S 00 1S";
String Mirpur_10     = "20 2S 10 2S";
String Agargaon      = "30 2S 20 2S";
String Shahbag       = "40 2S 30 2S";
String Motijheel     = "50 2S 40 2S";
int Available_Balance_A = random(100,250);
int Available_Balance_B = random(175,415);
int Available_Balance_C = random(0,8);
int Bus = random(1,10);
int rstPIN = 22;
int ssPIN  =  5;
MFRC522 mfrc522(ssPIN, rstPIN);
//Adafruit.io Setup
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME   "...................."
#define AIO_KEY        "aio_xOOa97FoJfLUiSjVNr......."
// BLUETOOTH CLIENT
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run
`make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
int bluedata;
// WIFI CLIENT
#define WLAN_SSID       "TP-LINK_D8B6"
#define WLAN_PASS       ".................."
WiFiClient client;
// MQTT CLIENT
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Publish TTPAFC = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME"/feeds/TTPAFC");
void MQTT_connect();
AsyncWebServer server(80);
TaskHandle_t Loop0;
  // Connection to WiFi access point.
  Serial.println();Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.mode(WIFI_STA);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("WiFi connected!");
  Serial.println("IP address: ");
  // Connection to BLE access point.
  btStart();
  Serial.println("Bluetooth On!");
  SerialBT.begin("ESP32_Bluetooth");
  Serial.println("The device started, now you can pair it with bluetooth!");
  // Connection to ASYNC access point.
  AsyncElegantOTA.begin(&server);
  server.begin();
  Serial.println("ASYNC server started!");
  SPI.begin();
  mfrc522.PCD_Init();
    xTaskCreatePinnedToCore(
                      Loop0code,
                      "Loop 0",
                      10000,
                      NULL,
                      1,
                      &Loop0,
                      0);
  Serial.println(Bus);
void Loop0code( void * pvParameters ) {
  for(;;){
          int distanceCm = ultrasonicSensor.measureDistanceCm();
          if (distanceCm <= 10)
            SerialBT.println("Scan");
            Serial.println(Message_G);
            Serial.println(Message_B);
            TTPAFC.publish(Message_G);
            TTPAFC.publish(Message_B);
   MQTT_connect();
   unsigned long currentTime = millis();
   if (millis() - lastConnectionTime > postInterval)
     lastConnectionTime = millis();
   while(SerialBT.available())
    bluedata = SerialBT.parseInt();
    delay(20);
    if (bluedata == 1) {
      Serial.println("Passenger boarded at 'Shahbag' station.");
      Serial.println("Passenger Name : A ");
      Serial.println(Message_F);
      Serial.println(Safety_Measurement);
      TTPAFC.publish("Passenger boarded at 'Shahbag' station.");
      TTPAFC.publish("Passenger Name : A ");
      TTPAFC.publish(Message_F);
      TTPAFC.publish(Safety_Measurement);
    else if (bluedata == 2) {
      Serial.println("Passenger boarded at 'Mirpur-10' station.");
      Serial.println("Passenger Name : B ");
      TTPAFC.publish("Passenger boarded at 'Mirpur-10' station.");
      TTPAFC.publish("Passenger Name : B ");
    else if (bluedata == 3) {
      Serial.println("Passenger boarded at 'Uttara' station.");
      TTPAFC.publish("Passenger boarded at 'Uttara' station.");
    else if (bluedata == 4) {
      Serial.println("Passenger boarded at 'Cantonment' station.");
      TTPAFC.publish("Passenger boarded at 'Cantonment' station.");
    else if (bluedata == 5) {
      Serial.println(Message_I);
      TTPAFC.publish(Message_I);
   //if ( ! mfrc522.PICC_IsNewCardPresent())
   // return;
  //if ( ! mfrc522.PICC_ReadCardSerial())
  // return;
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  content.toUpperCase();
 if (Bus == 1 || Bus == 3 || Bus == 5 || Bus == 7 || Bus == 9)
  if (content.substring(1) == Uttara)
    Serial.println("Bus currently at 'Uttara' station.");
    TTPAFC.publish("Bus currently at 'Uttara' station.");
        if (content.substring(1) == User_A)
            String Balance_A = String(Available_Balance_A);
            String Message_X = Message_U + Bus;
            String Message_Z = Message_A + Balance_A + BDT;
            const char* Message_K = Message_X.c_str();
            const char* Message_L = Message_Z.c_str();
            Serial.println(Message_K);
            Serial.println(Message_L);
            TTPAFC.publish(Message_K);
            TTPAFC.publish(Message_L);
                if (content.substring(1) == Mirpur_10)
                    Serial.println("Bus reached 'Mirpur-10' station.");
                    TTPAFC.publish("Bus reached 'Mirpur-10' station.");
                        Serial.println("Deducted BDT 30 from your account.");
                        int    Current_Balance_A = Available_Balance_A - 30;
                        String Message_S         = String(Current_Balance_A);
                        String Message           = Message_C + Message_S + BDT;
                        const char* Message1 = Message.c_str();
                        Serial.println(Message1);
                        TTPAFC.publish(Message1);
                      else{}
                 if (content.substring(1) == Agargaon)
                    Serial.println("Bus reached 'Agargaon' station.");
                    TTPAFC.publish("Bus reached 'Agargaon' station.");
                        Serial.println("Deducted BDT 40 from your account.");
                        int    Current_Balance_A = Available_Balance_A - 40;
                      else{}
                 if (content.substring(1) == Shahbag)
                    Serial.println("Bus reached 'Shahbag' station.");
                    TTPAFC.publish("Bus reached 'Shahbag' station.");
                        Serial.println("Deducted BDT 60 from your account.");
                        int    Current_Balance_A = Available_Balance_A - 60;
                      else{}
                 if (content.substring(1) == Motijheel)
                    Serial.println("Bus reached 'Motijheel' station.");
                    TTPAFC.publish("Bus reached 'Motijheel' station.");
                        Serial.println("Deducted BDT 70 from your account.");
                        int    Current_Balance_A = Available_Balance_A - 70;
                      else{}
        if (content.substring(1) == User_B)
            String Balance_B = String(Available_Balance_B);
            String Message_Z = Message_A + Balance_B + BDT;
                        int    Current_Balance_B = Available_Balance_B - 30;
                        String Message_S         = String(Current_Balance_B);
                      else{}
                        int    Current_Balance_B = Available_Balance_B - 40;
                      else{}
                        int    Current_Balance_B = Available_Balance_B - 60;
                      else{}
                        int    Current_Balance_B = Available_Balance_B - 70;
                      else{}
            if (content.substring(1) == User_C)
              String Balance_C = String(Available_Balance_C);
              String Message_Z = Message_A + Balance_C + BDT;
              Serial.println("User Name : C ");
              Serial.println(Message_T);
              Serial.println(Message_Y);
              TTPAFC.publish("User Name : C ");
              TTPAFC.publish(Message_T);
              TTPAFC.publish(Message_Y);
     else if (content.substring(1) == Mirpur_10)
       Serial.println("Bus currently at 'Mirpur-10' station.");
       TTPAFC.publish("Bus currently at 'Mirpur-10' station.");
                          Serial.println("Deducted BDT 10 from your account.");
                          int    Current_Balance_A = Available_Balance_A - 10;
                        else{}
                      else{}
                      else{}
                          int    Current_Balance_B = Available_Balance_B - 10;
                        else{}
                      else{}
                      else{}
    else if (content.substring(1) == Agargaon)
            Serial.println("Bus currently at 'Agargaon' station.");
            TTPAFC.publish("Bus currently at 'Agargaon' station.");
                   Serial.println("Passenger boarded at 'Agargaon' station.");
                        Serial.println("Deducted BDT 20 from your account.");
                        int    Current_Balance_A = Available_Balance_A - 20;
                      else{}
                      else{}
                        int    Current_Balance_B = Available_Balance_B - 20;
                      else{}
                      else{}
    else if (content.substring(1) == Shahbag)
            Serial.println("Bus currently at 'Shahbag' station.");
            TTPAFC.publish("Bus currently at 'Shahbag' station.");
                      else{}
                      else{}
 if (Bus == 2 || Bus == 4 || Bus == 6 || Bus == 8 || Bus == 10)
    Serial.println("Bus currently at 'Motijheel' station.");
    TTPAFC.publish("Bus currently at 'Motijheel' station.");
        Serial.println("Passenger boarded at 'Motijheel' station.");
                      else{}
                      else{}
                      else{}
                    Serial.println("Bus reached 'Uttara' station.");
                    TTPAFC.publish("Bus reached 'Uttara' station.");
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
                      else{}
        Serial.println("Passenger boarded at 'Mirpur-10' station");
                        Serial.println("Deducted BDT 30 from your account");
                      else{}
                      else{}
void MQTT_connect()
  int8_t ret;
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) {
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);
    retries--;
    if (retries == 0) {
      while (1);
   Serial.println("MQTT Connected!\n");
The problem I am facing is my code doesn't seem to work very well. I tried putting the --- if new card present and read card serial command in many possible ways but it just continue printing the card serial...I know it's a mess and I can't define my problem very well but I hope geeks like you all great people might be able to help me.....
1 more thing...What do I do if I want to print something once in a loop?
I need help with the core0 distance one....I want to send data to bluetooth and adafruit io but it sends millions(u know) of data and my adafruit account gets banned.
Here's a kinda chain of command diagram about what I want to do....
Edit* I am attaching that in comments section
I am not much of a good coder and I am really in grave need of help from u guys...
You are using the WiFi module and you are putting code onto core0, which is a very tricky thing to do because WiFi owns core0 when the module is enabled.
Put your tasks onto core1.
Okay...Will do but back to the main problem u got anything on that?
