Hello everyone,
I have a problem getting the ESP32 WROOM 30 to work with the Waveshare 4" TFT Touch Shield display ( ILI9486).
I suppose the set is not compatible .
My display configuration is as follows:
I count eight 4" TFT displays on the Waveshare website (some can be excluded). Post a link to your display and state the libraries you tried. Also link to processor board.
Else you might never get a useful answer.
I am too lazy to go search for that board. Does it have UNO type of headers?
I am also too lazy to check if the Waveshare code can be used with ESP32.
I would recommend to use TFT_eSPI with ESP32.
Note that (at first sight) the display has a SPI to parallel convert circuit (kludge), known as RPi version by TFT_eSPI.
Added: I just found my Waveshare 3.5" TFT display.
It looks the same. It also works with my ILI9486_SPI library.
Did you put the back trace info into the ESP32 exception decoder?
At this point.
Help us help you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
I tend to shy away from using GPIO_NUM_2 on the ESP32 as it drives the built in LED and under particular thingies can cause issue. Use GPIO_NUM_0 instead.
For CS pins on the ESP32 I tend to use GPIO_NUM_5 first and GPIO_NUM_15 second.
Sketch uses 262685 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16856 bytes (5%) of dynamic memory, leaving 310824 bytes for local variables. Maximum is 327680 bytes.
Much less than the claimed 16MB in your image header. Did you try at least twice?
But I will keep silent until I know your processor board and the board you select for compilation.
Yes, I have an ESP32 Dev Module.
Compiling the sketch with te Flash Size to 4Mb, the the endless loop of the serial disappears and I see the benchmark.
The TFT screen continues to remain blank.
Thank you, Roberto
Yes, it disappears, especially if I use the Flash Size 4MB.
I will soon be modifying my prototype with an ESP32-WROOM-32 Pinout, to avoid all possible problems.
Thank you, Roberto
I have modified my prototype board with an ESP32-WROOM-DEVKIT-32 pin and connected it as shown in the attached diagram, but I still cannot get it to run....
