Hi all.
Im trying to emulate a thrustmaster wheel using an ESP32.
I found this: https://rr-m.org/blog/thrustmaster-t300rs-steering-wheel-arduino-emulator/
With this code:
byte wheelState [8]; // local push-buttons state saved here
volatile byte pos;
void setup (void) {
DDRB &= B11110000; // digital pins 8,9,11 used as inputs. 10 - SS also input
PORTB |= B00001011; // 8,9,11 - pull-up to +VCC via internal 100k resistors.
DDRC &= B11000000; // pins 14-19 (A0 - A5) also used as digital inputs
PORTC |= B00111111; // pulled-up to +VCC via internal 100k resistors
DDRD &= B00100000; // digital pins 0,1,3,4,6,7 are inputs for buttons. 2 - also input - for external interrupt 0
PORTD |= B11011011; // 0,1,3,4,6,7 pulled-up to +VCC via internal 100k resistors
wheelState[0] = B11010001; // T300 PS wheel first data byte
wheelState[1] = B11111111; // second data byte - buttons
wheelState[2] = B11111111; // third data byte - buttons
wheelState[3] = B11111111; // this and below - not used, but wheelbase reads all 8 bytes...
wheelState[4] = B11111111;
wheelState[5] = B11111111;
wheelState[6] = B11111111;
wheelState[7] = B11111111;
//Serial.begin(9600); // Arduino debug console - occupies pins RX (0) and TX (1) on Uno
pinMode(MISO, OUTPUT); // arduino is a slave device
SPCR |= _BV(SPE); // Enables the SPI when 1
SPCR |= _BV(SPIE); // Enables the SPI interrupt when 1
// interrupt for SS rising edge. Arduino Uno Pin10 must be connected to Pin2!!!
attachInterrupt (0, ss_rising, RISING);
// Interrupt0 (external, pin 2) - prepare to start the transfer
void ss_rising () {
SPDR = wheelState[0]; // load first byte into SPI data register
pos = 1;
// SPI interrupt routine
ISR (SPI_STC_vect) {
SPDR = wheelState[pos++]; // load the next byte to SPI output register and return.
(I just copied arduino code, avoiding the large first comment, just for efficiency)
The first (and actually the one) question is, its possible to translate or rewrite that code to work with ESP32? (I dont want anyone to write it for me, maybe just hints, but i want to learn and achieve it, or unless, try it)
I have read in some pages that ESP32 cant act as SPI slave (only master) so, it is true? or there is anyway to do it?
In case that it could be possible, could you hint me where to search info on how to understand SPI on esp32? (I repeat myself, i wnat to learn, ask for coding its not my way)
Thanks!
