ESP32
I'm using the code below
Where is the rest of it ?
Yuppers, where's the res-o-it.
As a note the ESP32 has several hardware serial ports available and does not require software serial which does not work well above 9600 and does not work well with the ESP32. There are other ESP-esq software serial libraries but there are, also, 2 hardware serial ports you can use.
Forum did not allow me to post longer code.
You could have attached it
