Hello,
I get theses traces:
22:04:15.537 -> ESP-ROM:esp32c3-api1-20210207
22:04:15.537 -> Build:Feb 7 2021
22:04:15.537 -> rst:0x1 (POWERON),boot:0xe (SPI_FAST_FLASH_BOOT)
22:04:15.570 -> SPIWP:0xee
22:04:15.570 -> mode:DIO, clock div:1
22:04:15.570 -> load:0x3fcd6100,len:0x420
22:04:15.570 -> load:0x403ce000,len:0x90c
22:04:15.570 -> load:0x403d0000,len:0x236c
22:04:15.570 -> entry 0x403ce000
22:04:15.770 -> setup---begin
22:04:15.770 -> This chip has 1 cores
22:04:21.248 -> E (5769) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:21.414 -> E (5911) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:21.414 -> E (5911) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:21.414 -> E (5911) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:21.547 -> E (6058) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:21.547 -> E (6058) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:21.547 -> E (6058) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:21.679 -> E (6205) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:21.679 -> E (6205) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:21.713 -> E (6205) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:21.846 -> E (6352) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:21.846 -> E (6352) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:21.846 -> E (6352) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:21.912 -> E (6428) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:21.912 -> E (6428) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:21.912 -> E (6428) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:22.144 -> E (6646) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:22.144 -> E (6646) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:22.144 -> E (6646) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:22.410 -> E (6936) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:22.443 -> E (6936) ledc: ledc_update_duty(409): LEDC is not initialized
22:04:22.443 -> E (6936) ledc: ledc_get_duty(501): LEDC is not initialized
22:04:22.576 -> E (7083) ledc: ledc_set_duty(481): LEDC is not initialized
22:04:22.576 -> E (7083) ledc: ledc_update_duty(409): LEDC is not initialized
uint8_t buzzerPin=1;
pinMode(buzzerPin, OUTPUT);
for (int thisNote = 0; thisNote < notes * 2; thisNote = thisNote + 2) {
// calculates the duration of each note
divider = melody[thisNote + 1];
if (divider > 0) {
// regular note, just proceed
noteDuration = (wholenote) / divider;
} else if (divider < 0) {
// dotted notes are represented with negative durations!!
noteDuration = (wholenote) / abs(divider);
noteDuration *= 1.5; // increases the duration in half for dotted notes
// we only play the note for 90% of the duration, leaving 10% as a pause
tone(buzzerPin, melody[thisNote], noteDuration*0.9, BUZZER_CHANNEL);
// Wait for the specief duration before playing the next note.
delay(noteDuration);
// stop the waveform generation before the next note.
noTone(buzzerPin,BUZZER_CHANNEL);
I don't why, before my buzzer works, now i get theses traces and buzzer not works. I don't change my code.
Have you an idea?
Thank you.
