ESP32C3 not waking up from deep sleep with GPIO Button press
I am using an ESP32-C3 with deep sleep mode, and I want it to wake up when I press GPIO9. However, pressing the button does nothing.
Here is my setup
#include <Arduino.h>
#include "esp_sleep.h"
#include "driver/rtc_io.h"
#define WAKEUP_PIN 9
#define BUTTON_PIN_BITMASK 0x200000000 // 2^33 in hex
//extern "C" esp_err_t esp_sleep_enable_ext0_wakeup(gpio_num_t gpio_num, int level);
RTC_DATA_ATTR int bootCount = 0;
void printWakeupReason() {
  esp_sleep_wakeup_cause_t wakeup_reason = esp_sleep_get_wakeup_cause();
  switch (wakeup_reason) {
    case ESP_SLEEP_WAKEUP_EXT1:
      Serial.println("Wakeup caused by external signal using EXT1");
    case ESP_SLEEP_WAKEUP_EXT0:
      Serial.println("Wakeup caused by external signal using EXT0");
    case ESP_SLEEP_WAKEUP_TIMER:
      Serial.println("Wakeup caused by timer");
    default:
      Serial.printf("Wakeup not caused by deep sleep: %d\n", wakeup_reason);
  delay(1000); // Give time to open the Serial Monitor
  bootCount++;
  Serial.printf("Boot number: %d\n", bootCount);
  printWakeupReason();
  esp_deep_sleep_enable_gpio_wakeup(1 << 9, ESP_GPIO_WAKEUP_GPIO_HIGH);
  Serial.println("Entering deep sleep in 5 seconds. Press the button (GPIO12 pulled LOW) to wake up.");
  delay(5000);
  Serial.println("Entering deep sleep now.");
  esp_deep_sleep_start();
Post a link to where you got the example code that you have used and say which version of the ESP32 Arduino core that you are using. Say also if you have a resistor connected to pin 9.
Link: arduino-esp32/libraries/ESP32/examples/DeepSleep/ExternalWakeUp/ExternalWakeUp.ino at master · espressif/arduino-esp32 · GitHub
Does gpio 9 have a resistor? yes
I don't know the version of the arduino core that i am using
According to this for an ESP32-C3 GPIO & RTC GPIO - ESP32-C3 - — ESP-IDF Programming Guide v5.2.5 documentation , you can use only GPIO pins 0, 1, 3, 4 and 5 and also, if you know what you are doing, pin 2 as well. These are "RTC" pins.
You've made some changes to the example code you have been following. For example, this macro: #define BUTTON_PIN_BITMASK(GPIO) (1ULL << GPIO) // 2 ^ GPIO_NUMBER in hex
What is your explanation for this change ?
Try, by using Google or other means, to determine which version of the ESP32 Arduino core that you are using. It will be something like 2.x or 3.x .
The instructions say the following. Are you using a pulldown resistor on the selected button pin? : "Push Button to GPIO 33 pulled down with a 10K Ohm resistor"
Step 1 for you, apart from answering the open questions, is to choose a valid pin for the button.
EDIT
OK. It is clear that you are using ESP32 Arduino core 3.x . Your code at least compiles under 3.x.
Most of the examples of DeepSleep I have looked at, including the one you quoted in post #3, and including the official Espressif one are intended for 2.x
EDIT 2
This appears to work using an ESP32-C3 devkitC-02. Tested with ESP32 Arduino core 3.0.5
You must use "RTC" pins but NOT 0 or 1. That is 2,3,4 and 5 work as wake up sources.
ESP32 C3  Deep Sleep and wakeup
1. works with RTC pins 2, 3, 4 and 5 but not 0 and 1
   see https://github.com/espressif/arduino-esp32/issues/6656
   and https://github.com/espressif/arduino-esp32/issues/8447
#define DEBUG 1
// #define WAKEUP_PIN 1  // tidy
RTC_DATA_ATTR int bootCount;
esp_err_t errRc;
int esp_deep_sleep_enable_gpio_wakeup(uint64_t, int);
      if (DEBUG) Serial.println("Wakeup caused by external signal using EXT1");
      if (DEBUG) Serial.println("Wakeup caused by external signal using EXT0");
      if (DEBUG) Serial.println("Wakeup caused by timer");
    case ESP_SLEEP_WAKEUP_GPIO:
      if (DEBUG) Serial.println("Wakeup caused by GPIO");
    default:
      if (DEBUG) Serial.printf("Wakeup not caused by deep sleep: %d\n", wakeup_reason);
  if (DEBUG) Serial.begin(115200);
  pinMode(LED_BUILTIN, OUTPUT);
  for (int i = 0; i < 3; i++) {
    digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
    digitalWrite(LED_BUILTIN, LOW);  // turn the LED on (HIGH is the voltage level)
  if (DEBUG) Serial.println("starting. . . ");
  bootCount++;
  if (DEBUG) Serial.printf("Boot number: %d\n", bootCount);
  // errRc = esp_deep_sleep_enable_gpio_wakeup(1ull << WAKEUP_PIN, ESP_GPIO_WAKEUP_GPIO_HIGH);  // $$
  errRc = esp_deep_sleep_enable_gpio_wakeup(1ull | 0b11111, ESP_GPIO_WAKEUP_GPIO_HIGH);  // all RTC pins can wake 0 to 5
  if (DEBUG) Serial.printf("errRc  (A): %d\n", (int)errRc);
  if (DEBUG) Serial.println("Entering deep sleep in 5 seconds. Press the button (GPIOx pulled HIGH) to wake up.");  // $$
  delay(5000);
  if (DEBUG) Serial.println("Entering deep sleep now.");
