Anyone looking for a code that only detects faces, this one does it. When detecting, the led-flash turns on and keeps it on as long as the detection is true.
What I'm researching is how to take a picture only when a face is detected. That is, switching from frame to photo, taking the photo, then switching back to frame and continuing to detect faces.
If anyone knows and wants to help by posting how this code should look, I appreciate it.
#include "esp_camera.h"
#include "fd_forward.h"
int cron;
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#define flash 4
bool initCamera() {
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_CIF;
config.jpeg_quality = 10;
config.fb_count = 1;
esp_err_t result = esp_camera_init(&config);
if (result != ESP_OK) {
return false;
return true;
mtmn_config_t mtmn_config = {0};
int detections = 0;
pinMode(flash, OUTPUT);
if (!initCamera()) {
Serial.printf("Failed to initialize camera...");
return;
mtmn_config = mtmn_init_config();
camera_fb_t * frame;
frame = esp_camera_fb_get();
dl_matrix3du_t *image_matrix = dl_matrix3du_alloc(1, frame->width, frame->height, 3);
fmt2rgb888(frame->buf, frame->len, frame->format, image_matrix->item);
esp_camera_fb_return(frame);
box_array_t *boxes = face_detect(image_matrix, &mtmn_config);
if (boxes != NULL) {
detections = detections+1;
//Serial.printf("Faces detected %d times \n", detections);
digitalWrite(flash, HIGH);
cron = 0;
dl_lib_free(boxes->score);
dl_lib_free(boxes->box);
dl_lib_free(boxes->landmark);
dl_lib_free(boxes);
cron++;
Serial.println(cron);
if (cron > 1) {
digitalWrite(flash, LOW);
cron = 0;
// Serial.println("Stop detection");
dl_matrix3du_free(image_matrix);
