ESP32DEV C3 Serial Port Not Working Correctly
With this very simple code, the LED is blinking correctly as expected, but there are no outputs from the serial ports. I've tried setting the baud rate to 9600 and 115200 but didn't work. I've tried reset method and reinstalling Arduino but still have no outputs.
  pinMode(1,OUTPUT);
  digitalWrite(1,HIGH);
  while(!Serial);
  delay(100);
  Serial.println("hello");
  digitalWrite(1,LOW);
  delay(100);
Did you activate the "USB CDC on boot option"?
Are you using the following ESP32 C3 Super Mini board?
Which IDE are you using? IDE 1.x?
Hi @kp4good ,
the led connected to pin 1 quite likely interferes with Serial on UART0
Source: https://randomnerdtutorials.com/esp32-uart-communication-serial-arduino/#esp32-uart-peripherals
What happens if you move the led to a different pin?
Good luck!
ec2021
Thank you for your advice! Seems like there are conflicts between the pins. After switching to a different project and unplugging the pins the Serial seems to be working fine.
