I bought this camera ESP32S-CAM and I cannot for the life of me get it to work. I have all of these available cameras in the camera example. Which one do I select?
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_CAMS3_UNIT // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
//#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
In the list of ESP boards in Tools>>>Board Manager>>>ESP32 I have huge amount of boards to select from and I have no idea which to select ![]()
Can anyone help me out here please?
On the board selected, I get this error:
E (692) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
Camera init failed with error 0x105=========== After Setup Start ============
============ Before Setup End ============
[ 1223][V][esp32-hal-uart.c:408] uartBegin(): UART0 baud(115200) Mode(800001c) rxPin(3) txPin(1)
[ 1231][V][esp32-hal-uart.c:497] uartBegin(): UART0 not installed. Starting installation
[ 1242][V][esp32-hal-uart.c:560] uartBegin(): UART0 initialization done.
[ 1257][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x40179ab8
[ 1268][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type GPIO (1) with bus 0xe
[ 1278][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x40179ab8
[ 1289][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 14 successfully set to type GPIO (1) with bus 0xf
INTERNAL Memory Info:
