ESP32S3 Boot Loops In Serial Monitor
Hey, I have an ESP32S3 that I'm using with Squareline Studio. It bootloops with the Arduino & TFT_eSPI choice for no apparent reason even though I've tested this near exact code with an ESP32 and it works just fine. please take a look at the code below. Note the ui.ino is the premade one
ui.ino
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <ui.h>
/*Don't forget to set Sketchbook location in File/Preferences to the path of your UI project (the parent foder of this INO file)*/
/*Change to your screen resolution*/
static const uint16_t screenWidth  = 160;
static const uint16_t screenHeight = 128;
static lv_disp_draw_buf_t draw_buf;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
    Serial.printf(buf);
    Serial.flush();
#endif
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
    uint32_t w = ( area->x2 - area->x1 + 1 );
    uint32_t h = ( area->y2 - area->y1 + 1 );
    tft.startWrite();
    tft.setAddrWindow( area->x1, area->y1, w, h );
    tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
    tft.endWrite();
    lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
    uint16_t touchX = 0, touchY = 0;
    bool touched = false;//tft.getTouch( &touchX, &touchY, 600 );
    if( !touched )
        data->state = LV_INDEV_STATE_REL;
        data->state = LV_INDEV_STATE_PR;
        /*Set the coordinates*/
        data->point.x = touchX;
        data->point.y = touchY;
        Serial.print( "Data x " );
        Serial.println( touchX );
        Serial.print( "Data y " );
        Serial.println( touchY );
    Serial.begin( 115200 ); /* prepare for possible serial debug */
    String LVGL_Arduino = "Hello Arduino! ";
    LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
    Serial.println( LVGL_Arduino );
    Serial.println( "I am LVGL_Arduino" );
    lv_init();
#if LV_USE_LOG != 0
    lv_log_register_print_cb( my_print ); /* register print function for debugging */
#endif
    tft.begin();          /* TFT init */
    tft.setRotation( 3 ); /* Landscape orientation, flipped */
    lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
    /*Initialize the display*/
    static lv_disp_drv_t disp_drv;
    lv_disp_drv_init( &disp_drv );
    /*Change the following line to your display resolution*/
    disp_drv.hor_res = screenWidth;
    disp_drv.ver_res = screenHeight;
    disp_drv.flush_cb = my_disp_flush;
    disp_drv.draw_buf = &draw_buf;
    lv_disp_drv_register( &disp_drv );
    /*Initialize the (dummy) input device driver*/
    static lv_indev_drv_t indev_drv;
    lv_indev_drv_init( &indev_drv );
    indev_drv.type = LV_INDEV_TYPE_POINTER;
    indev_drv.read_cb = my_touchpad_read;
    lv_indev_drv_register( &indev_drv );
    ui_init();
    Serial.println( "Setup done" );
    lv_timer_handler(); /* let the GUI do its work */
    delay(5);
User_Setup.h
#define ST7735_DRIVER
#define TFT_WIDTH  128
#define TFT_HEIGHT 160
#define ST7735_BLACKTAB
#define TFT_MOSI  11  // ESP32-S3 MOSI
#define TFT_SCLK  12  // ESP32-S3 SCK
#define TFT_CS    10  // ESP32-S3 CS
#define TFT_DC    2   // Data/Command pin
#define TFT_RST   4   // Reset pin, or -1 if tied to 3.3V
#define LOAD_GLCD
#define LOAD_FONT2
#define LOAD_FONT4
#define LOAD_FONT6
#define LOAD_FONT7
#define LOAD_FONT8
#define SPI_FREQUENCY  40000000
Error in serial monitor
���ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x4037893a
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x116c
load:0x403c8700,len:0xc2c
load:0x403cb700,len:0x3108
entry 0x403c88b8
Hello Arduino! V8.3.11
I am LVGL_Arduino
Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x42025a2f  PS      : 0x00060730  A0      : 0x82025b08  A1      : 0x3fcebf40
Please take a look and I will be eternally grateful. Thanks for your time!
try using HSPI, e.g.
#define USE_HSPI_PORT     // << required otherwise ESP32S3 goes into reboot loop
This worked. Thank you so much!
if the problem is solved click the Solution button at the bottom of the reply that answered the question - this helps others with a similar question
