Elecrow 5 inch display crashing/not looping
I am having problems with an Elecrow 5 inch ESP32S3 display. I have followed their Wiki tutorial ( CrowPanel ESP32 HMI 5.0-inch Display - Elecrow Wiki ), it compiles and when uploaded I have a working display. Drop downs, sliders, buttons all work. However, it crashes somewhere as it is not running the loop.
In their code, the last line of setup is Serial.println("Setup done"); and I have added Serial.println("Looping…"); at the start of the loop. No output on the serial monitor after the boot messages. I have enabled USB CDC on boot.
Boot messages are:
18:08:27.241 -> ESP-ROM:esp32s3-20210327
18:08:27.241 -> Build:Mar 27 2021
18:08:27.241 -> rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
18:08:27.241 -> SPIWP:0xee
18:08:27.241 -> mode:DIO, clock div:1
18:08:27.241 -> load:0x3fce3808,len:0x4bc
18:08:27.241 -> load:0x403c9700,len:0xbd8
18:08:27.241 -> load:0x403cc700,len:0x2a0c
18:08:27.241 -> entry 0x403c98d0
18:08:27.370 -> E (131) esp_core_dump_flash: No core dump partition found!
18:08:27.370 -> E (132) esp_core_dump_flash: No core dump partition found!
18:08:27.738 -> E (388) gpio: gpio_set_level(227): GPIO output gpio_num error
18:08:27.738 -> E (389) gpio: gpio_set_level(227): GPIO output gpio_num error
18:08:27.738 -> E (399) gpio: gpio_set_level(227): GPIO output gpio_num error
18:08:27.778 -> E (400) gpio: gpio_set_level(227): GPIO output gpio_num error
18:08:27.778 -> E (405) gpio: gpio_set_level(227): GPIO output gpio_num error
The code generated by Squareline Studio is below. I have used the libraries they provide and ESP32 2.0.15 which is the one they suggest. Any ideas would be much appreciated. Thanks.
#include <Arduino.h>
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
#include <lvgl.h>
#include <ui.h>
/*Don't forget to set Sketchbook location in File/Preferences to the path of your UI project (the parent foder of this INO file)*/
enum BoardConstants { TFT_BL = 2,
                      SERIAL_BAUD = 9600,
                      LVGL_BUFFER_RATIO = 6 };
class LGFX : public lgfx::LGFX_Device {
public:
  lgfx::Bus_RGB _bus_instance;
  lgfx::Panel_RGB _panel_instance;
  LGFX(void) {
      auto cfg = _bus_instance.config();
      cfg.panel = &_panel_instance;
      cfg.pin_d0 = GPIO_NUM_8;   // B0
      cfg.pin_d1 = GPIO_NUM_3;   // B1
      cfg.pin_d2 = GPIO_NUM_46;  // B2
      cfg.pin_d3 = GPIO_NUM_9;   // B3
      cfg.pin_d4 = GPIO_NUM_1;   // B4
      cfg.pin_d5 = GPIO_NUM_5;   // G0
      cfg.pin_d6 = GPIO_NUM_6;   // G1
      cfg.pin_d7 = GPIO_NUM_7;   // G2
      cfg.pin_d8 = GPIO_NUM_15;  // G3
      cfg.pin_d9 = GPIO_NUM_16;  // G4
      cfg.pin_d10 = GPIO_NUM_4;  // G5
      cfg.pin_d11 = GPIO_NUM_45;  // R0
      cfg.pin_d12 = GPIO_NUM_48;  // R1
      cfg.pin_d13 = GPIO_NUM_47;  // R2
      cfg.pin_d14 = GPIO_NUM_21;  // R3
      cfg.pin_d15 = GPIO_NUM_14;  // R4
      cfg.pin_henable = GPIO_NUM_40;
      cfg.pin_vsync = GPIO_NUM_41;
      cfg.pin_hsync = GPIO_NUM_39;
      cfg.pin_pclk = GPIO_NUM_0;
      cfg.freq_write = 15000000;
      cfg.hsync_polarity = 0;
      cfg.hsync_front_porch = 8;
      cfg.hsync_pulse_width = 4;
      cfg.hsync_back_porch = 43;
      cfg.vsync_polarity = 0;
      cfg.vsync_front_porch = 8;
      cfg.vsync_pulse_width = 4;
      cfg.vsync_back_porch = 12;
      cfg.pclk_active_neg = 1;
      cfg.de_idle_high = 0;
      cfg.pclk_idle_high = 0;
      _bus_instance.config(cfg);
      auto cfg = _panel_instance.config();
      cfg.memory_width = 800;
      cfg.memory_height = 480;
      cfg.panel_width = 800;
      cfg.panel_height = 480;
      cfg.offset_x = 0;
      cfg.offset_y = 0;
      _panel_instance.config(cfg);
    _panel_instance.setBus(&_bus_instance);
    setPanel(&_panel_instance);
LGFX lcd;
/*Change to your screen resolution*/
static const uint16_t screenWidth = 800;
static const uint16_t screenHeight = 480;
enum { SCREENBUFFER_SIZE_PIXELS = screenWidth * screenHeight / LVGL_BUFFER_RATIO };
static lv_color_t buf[SCREENBUFFER_SIZE_PIXELS];
#include "touch.h"
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char* buf) {
  Serial.printf(buf);
  Serial.flush();
#endif
/* Display flushing */
void my_disp_flush(lv_display_t* disp, const lv_area_t* area, uint8_t* pixelmap) {
  uint32_t w = (area->x2 - area->x1 + 1);
  uint32_t h = (area->y2 - area->y1 + 1);
  //if (LV_COLOR_16_SWAP) {
  //    size_t len = lv_area_get_size( area );
  //    lv_draw_sw_rgb565_swap( pixelmap, len );
  lcd.pushImageDMA(area->x1, area->y1, w, h, (lgfx::rgb565_t*)pixelmap);
  lv_disp_flush_ready(disp);
//Read the touchpad
void my_touchpad_read(lv_indev_t* indev, lv_indev_data_t* data) {
  if (touch_has_signal()) {
    if (touch_touched()) {
      data->state = LV_INDEV_STATE_PR;
      //Set the coordinates
      data->point.x = touch_last_x;
      data->point.y = touch_last_y;
      //Serial.print( "Data x :" );
      //Serial.println( touch_last_x );
      //Serial.print( "Data y :" );
      //Serial.println( touch_last_y );
    } else if (touch_released()) {
      data->state = LV_INDEV_STATE_REL;
  delay(15);
/*Set tick routine needed for LVGL internal timings*/
static uint32_t my_tick_get_cb(void) {
  return millis();
  Serial.begin(115200); /* prepare for possible serial debug */
  //Init Display
  lcd.begin();
  lcd.fillScreen(TFT_BLACK);
  delay(200);
  lv_init();
  delay(100);
  touch_init();
  static lv_disp_t* disp;
  disp = lv_display_create(screenWidth, screenHeight);
  lv_display_set_buffers(disp, buf, NULL, SCREENBUFFER_SIZE_PIXELS * sizeof(lv_color_t), LV_DISPLAY_RENDER_MODE_PARTIAL);
  lv_display_set_flush_cb(disp, my_disp_flush);
  static lv_indev_t* indev;
  indev = lv_indev_create();
  lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER);
  lv_indev_set_read_cb(indev, my_touchpad_read);
  lv_tick_set_cb(my_tick_get_cb);
  pinMode(TFT_BL, OUTPUT);
  digitalWrite(TFT_BL, HIGH);
  ui_init();
  //lcd.fillScreen(TFT_BLACK);
  Serial.println("Looping...");
  lv_timer_handler(); /* let the GUI do its work */
  delay(5);
Just an update for anyone else that gets stuck on this and finds this thread.
The Elecrow display is running fine but the Serial.print function is broken. I have no idea why or how to fix it because I lack the knowledge. I now have the I2C bus working and am writing the debug messages directly to the display.
For anyone that might have an idea, I have found out the following. The Serial.begin function is locked to 115200. You can put any value in the brackets but it doesn’t change. The boot messages are always output at 115200. Is this standard on the ESP32?
If you start setup with a Serial.begin and then immediately Serial.print you still get no output. So I don’t believe anything afterwards in setup is a problem.
I am just a hobbyist learning as I go, so it may be something simple that I am overlooking.
Have fun everyone…
try disabling it?
Thank you, Horace. Everything I have read says to enable “USB CDC on Boot”, but your suggestion was correct and it works fine disabled.
I have the to ESP32’s talking over ESPNOW so we are making progress.
