Esp8266 -01 RX und TX als GPIO verwenden
Hallo ich brauche für mein Projekt 4 GPIO-Pins und will RX und TX als GPIO verwenden. Leider komme ich nicht mehr weiter.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
// wireless network credentials:
const char* ssid = "xxxxx";
const char* password = "xxxxx";
// hostname for this system:
const char* host = "webcontrol";
// define GPIO pins:
const int output1 = 0;    //GPIO0
const int output2 = 2;    //GPIO2
const int output3 = 1;    //TX GPIO1
const int output4 = 3;    //RX GPIO3
// output status variables:
boolean output1_state = false;
boolean output2_state = false;
boolean output3_state = false;
boolean output4_state = false;
// web server on port 80:
ESP8266WebServer server(80);
String getContent()
  // create content for the website:
  String content = "<html><head><title>ESP8266 WebControl</title></head><body>";
  content += "Home Control!
  if (output1_state)
    content += "Output1: <a href=\"output1\"><button>ON</button></a>
    Serial.print("Output1: ON");
    Serial.print('\n');
    content += "Output1: <a href=\"output1\"><button>OFF</button></a>
    Serial.print("Output1: OFF");
    Serial.print('\n');
  if (output2_state)
    content += "Output2: <a href=\"output2\"><button>ON</button></a>
    Serial.print("Output2: ON");
    Serial.print('\n');
    content += "Output2: <a href=\"output2\"><button>OFF</button></a>
    Serial.print("Output2: OFF");
    Serial.print('\n');
  if (output3_state)
    content += "Output3: <a href=\"output3\"><button>ON</button></a>
    Serial.print("Output3: ON");
    Serial.print('\n');
    content += "Output3: <a href=\"output3\"><button>OFF</button></a>
    Serial.print("Output3: OFF");
    Serial.print('\n');
  if (output4_state)
    content += "Output4: <a href=\"output4\"><button>ON</button></a>
    Serial.print("Output4: ON");
    Serial.print('\n');
    content += "Output4: <a href=\"output4\"><button>OFF</button></a>
    Serial.print("Output4: OFF");
    Serial.print('\n');
Serial.print('\n');
  content += "</body></html>";
  return content;
  // configure GPIO 0 and GPIO 2 as outputs:
  pinMode(output1, OUTPUT);
  pinMode(output2, OUTPUT);
  // GPIO1 and GPIO3
  pinMode(output3, OUTPUT);
  pinMode(output4, OUTPUT);
  // set outputs to low:
  digitalWrite(output1, LOW);
  digitalWrite(output2, LOW);
  digitalWrite(output3, LOW);
  digitalWrite(output4, LOW);
  // initialize serial port for debugging purpose:
  // connect to the wireless network:
  WiFi.begin(ssid, password);
  // wait for wireless network connection and print connection settings:
  Serial.println("");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("Wireless network connection established.");
  Serial.print("SSID: ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  // initialize mDNS:
  if (MDNS.begin(host))
    Serial.println("mDNS responder started");
  MDNS.addService("http", "tcp", 80);
  // start HTTP server:
  server.begin();
  Serial.println("HTTP server started");
  // print start page:
  server.on("/", [](){
    server.send(200, "text/html", getContent());
                                                // control output1:
  server.on("/output1", [](){
    if (output1_state)
      digitalWrite(output1, HIGH);
      output1_state = true;
                                                  // control output2:
  server.on("/output2", [](){
    if (output2_state)
      digitalWrite(output2, HIGH);
      output2_state = true;
                                                  // control output3:
  server.on("/output3", [](){
    if (output3_state)
      digitalWrite(output3, HIGH);
      output3_state = true;
                                                    // control output4:
  server.on("/output4", [](){
    if (output4_state)
      digitalWrite(output4, HIGH);
      output4_state = true;
  // handle HTTP request:
  server.handleClient();
Grüße Manuel
Was soll es für einen Sinn haben, einen neuen Thread aufzumachen, wenn das Thema schon hier behandelt wird?
Gruß Tommy
Und noch weniger Sinn macht es, die GPIOs alle als solche zu definieren und danach die serielle Schnittstelle benutzen
Alle die in so einem Forum sind brauchen Hilfe. Wäre es so schwer mir zu sagen was nicht passt, dass ich die RX und TX als GPIO verwenden kann. Bzw. mir sagen was ich im Code verändern muss das es funktioniert?
Gruß Manuel
Hi
RX ist der Eingang für die serielle Komminikation, TX der Ausgang.
Wenn Du jetzt an den Ausgang eine LED, ein Relais, einen Stepper -Treiber hängst - was glaubst Du passiert, wenn Du Serial.print() benutzt?
Ja: Die LED, das Relais, der Stepper wird ungewollt Leben zeigen, da der Pin, wie DU es befiehlst, gerade digitale Signale raushaut.
Wenn die LED ein Laser ist, ist Das auch hier eher 'unschön'.
Dem Relais werden die äußerst kurzen Impulse wohl egal sein, Es wird Dir 'nur' das Signal verschleppen.
Entweder Du benutzt die Pins für die Kommunikation, oder für Deine Aktorik.
Beides zusammen ist zwar umständlich möglich, muß aber dann auch umständlich gemacht werden.
Klar ist der Einstiegsgrund in ein Forum meist ein Problem, nach Dessen Lösung man sucht - war bei mir nicht anders.
Wenn Dir also Dein Sketch mit auskommentierten Serial.print() als 'Lösung' ausreicht, denke Dir einfach, ich hätte überall // davor geschrieben.
... ich wage Es kaum auszusprechen: Dir wird dadurch die Funktionalität der Ausgabe im Terminal flöten gehen ... kA, ob Du Das bereits überblicken kannst, da Du ja eh nur Lösungen und keine Hintergründe dazu haben möchtest, muß ich davon ausgehen, daß der Sketch ähnlich entstanden sein wird ...
Ja, etwas überspritzt formuliert!
MfG und frohes Fest
Danke für die schnelle Hilfe werde ich mal ausprobieren! :slight_smile:
Das hab ich auch schon bemerkt, dass der TX immer ein Signal gibt und ich ne LED ansteuern kann aber die kurzen Impulse nicht fürs Relais reichen.
Habe auch gesehen das man das mit de I2C Bus realisieren kann, werde auch das probieren.
Grüß Manuel.
Ps: Frohes Fest an ALLE!
