ESP8266-01 to Arduino Uno R3 RF module communication
Good day pals, I've been trying for weeks to get my ESP-01 to talk to an arduino board using RF module with no success.
First, I connected the transmitter data pin to the ESP gpio 2 pin, the Vcc and Gnd pins came from a battery. The ESP is connected via USB to Serial converter to my computer. The RF receiver is connected to the arduino. This never seemed to show anything on the serial monitor.
Now, I removed the battery power for the transmitter and powered it from the arduino and it starts talking (same code). Please How do I get them to function independently with separate power sources.
The transmitter
  Example for different sending methods
  https://github.com/sui77/rc-switch/
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
  // Transmitter is connected to Arduino Pin #10
  mySwitch.enableTransmit(2);
  // Optional set protocol (default is 1, will work for most outlets)
  // mySwitch.setProtocol(2);
  // Optional set pulse length.
  // mySwitch.setPulseLength(320);
  // Optional set number of transmission repetitions.
  // mySwitch.setRepeatTransmit(15);
  /* See Example: TypeA_WithDIPSwitches */
  mySwitch.switchOn("11111", "00010");
  mySwitch.switchOff("11111", "00010");
  /* Same switch as above, but using decimal code */
  mySwitch.send(5393, 24);
  mySwitch.send(5396, 24);
  /* Same switch as above, but using binary code */
  mySwitch.send("000000000001010100010001");
  mySwitch.send("000000000001010100010100");
  /* Same switch as above, but tri-state code */
  mySwitch.sendTriState("00000FFF0F0F");
  mySwitch.sendTriState("00000FFF0FF0");
  delay(5000);
The receiver
  Simple example for receiving
  pinMode(13,OUTPUT);
  digitalWrite(13,0);
  mySwitch.enableReceive(0);  // Receiver on interrupt 0 => that is pin #2
  if (mySwitch.available()) {
    digitalWrite(13,1);
    Serial.print("Received ");
    Serial.print( mySwitch.getReceivedValue() );
    Serial.print(" / ");
    Serial.print( mySwitch.getReceivedBitlength() );
    Serial.print("bit ");
    Serial.print("Protocol: ");
    Serial.println( mySwitch.getReceivedProtocol() );
    mySwitch.resetAvailable();
    digitalWrite(13,0);
You need to connect the grounds.
Do you mean I must have common ground for both devices to work ?
Yes
