Problems with ESP-01 transmitter to Arduino receiver using RCSwitch library
Good day all.
I'm trying to make an IoT device with ESP8266-01 connected to an RF transmitter to send data to arduino with RCSwitch library.
I have gotten the ESP-01 to send data through GPIO 2 and i confirmed its transmitting something with an led connected to the data pin of my transmitter. But strangely, the receiver data pin with i connected to arduino pin 7 is always "high" and the serial monitor shows nothing being received.
Please can someone tell me what I've done wrongly and how I can get it working. Thanks. My code is below.
The ESP-01 transmitter code
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
/* Set these to your desired credentials. */
const char *ssid = "My_Home";
const char *password = "password";
long code = 0;
String response_data = "";
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
 * connected to this access point to see it.
void root()
  send_response("<h1>Welcome Home</h1>");
void check_connection()
  send_response("<h1>000</h1>");
void entrance_light_ON()
  response_data = "<h1>101</h1>";
  code = response_data.substring(4,7).toInt();
  sendCode(code);
  send_response(response_data);
  delay(1);
  //setup transmitter
  mySwitch.enableTransmit(2);   //transmit through GPIO 2
  mySwitch.setPulseLength(180);
	Serial.print("Configuring access point...\n");
	/* You can remove the password parameter if you want the AP to be open. */
	WiFi.softAP(ssid, password);
	IPAddress myIP = WiFi.softAPIP();
	Serial.print("AP IP address: ");
	Serial.println(myIP);
	server.on("/", root);
  server.on("/L_000",check_connection);
  //ON commands
  server.on("/L_101",entrance_light_ON);
server.begin();
	Serial.println("HTTP server started");
	server.handleClient();
The Receiver Code
  Serial.println("Started");
  mySwitch.enableReceive(7);
  if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.print( mySwitch.getReceivedValue() );
    Serial.print(" / ");
    Serial.print( mySwitch.getReceivedBitlength() );
    Serial.print("bit ");
    Serial.print("Protocol: ");
    Serial.println( mySwitch.getReceivedProtocol() );
    mySwitch.resetAvailable();
  mySwitch.enableReceive(7);  // Receiver on interrupt 0 => that is pin #2
Which pin is the receiver actually attached to ?
Its attached to arduino pin 7
JVT:
So is the comment relevant and is pin 7 interrupt 0 ?
Honestly, I'm new to working with ESP and RF modules. I really don't understand the Interrupt 0. I just connected my receiver's data pin to arduino pin 7. Please do you think my transmitter code really works. I really do appreciate your responses. Thanks a lot.
