i use this program for esp8266-01 with arduino uno
#include <WiFiEsp.h>
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include <SoftwareSerial.h>
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
char ssid[] = "DJAWEB_0D19C"; // your network SSID (name)
char pass[] = "2F088C732CAFE"; // your network password
int status = WL_IDLE_STATUS;
int ledStatus = LOW;
int led2 = 9;
WiFiEspServer server(80);
// use a ring buffer to increase speed and reduce memory allocation
RingBuffer buf(8);
pinMode(9, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT); // initialize digital pin LED_BUILTIN as an output.
Serial.begin(115200); // initialize serial for debugging
Serial1.begin(9600); // initialize serial for ESP module
WiFi.init(&Serial1); // initialize ESP module
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
Serial.println("You're connected to the network");
printWifiStatus();
// start the web server on port 80
server.begin();
WiFiEspClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("New client"); // print a message out the serial port
buf.init(); // initialize the circular buffer
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
buf.push(c); // push it to the ring buffer
// printing the stream to the serial monitor will slow down
// the receiving of data from the ESP filling the serial buffer
//Serial.write(c);
// you got two newline characters in a row
// that's the end of the HTTP request, so send a response
if (buf.endsWith("\r\n\r\n")) {
sendHttpResponse(client);
// Check to see if the client request was "GET /H" or "GET /L":
if (buf.endsWith("GET /H")) {
Serial.println("Turn led ON");
//ledStatus = HIGH;
digitalWrite(9, HIGH); // turn the LED on (HIGH is the voltage level)
else if (buf.endsWith("GET /L")) {
Serial.println("Turn led OFF");
// ledStatus = LOW;
digitalWrite(9, LOW); // turn the LED off by making the voltage LOW
else if (buf.endsWith("GET /G")) {
Serial.println("Turn led2 ON");
digitalWrite(13, HIGH); // turn the LED off by making the voltage LOW
else if (buf.endsWith("GET /M")) {
Serial.println("Turn led2 OFF");
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
// close the connection
client.stop();
Serial.println("Client disconnected");
void sendHttpResponse(WiFiEspClient client)
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("The LED is ");
client.print(ledStatus);
client.println("
client.println("
client.println("Click <a href=\"/H\">here</a> turn the LED on
client.println("Click <a href=\"/L\">here</a> turn the LED off
client.println("Click <a href=\"/G\">here</a> turn the LED2 on
client.println("Click <a href=\"/K\">here</a> turn the LED2 off
// The HTTP response ends with another blank line:
client.println();
void printWifiStatus()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print where to go in the browser
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
problem number one when i add LED number 2 http page not complete operation stay waiting but it work.
problem number two when i use this program with arduino mega , esp8266 not working and led blue of esp8266 not blink
