ESP8266-01 won't connect to AWS IoT MQTT
Hello. My ESP8266-01, connected through Arduino UNO, won't connect to the AWS IoT through MQTT. I want to send a test message, but it will be stuck at "Connecting to AWS IOT.......". The ESP module connects to the local WiFi network, and the certificate of my AWS Thing and the policy were correctly created and attached in code. I want to mention that the output of the console will be correct only if I set the baud rate to 74880, otherwise artifacts will be shown.
This is my test code:
#include "Arduino.h"
#include "aws_certificate.h"
#include "aws_parameter.h"
#include "wifi_credential.h"
#include "ESP8266WiFi.h"
#include <MQTTClient.h>
#include <ArduinoJson.h>
// Secure connection
WiFiClientSecure client = WiFiClientSecure();
// Client MQTT
MQTTClient clientMQTT = MQTTClient(256);
// Callback for every message on the topic subscribed
void messageCallback(String &topic, String &payload);
// Establish connection to MQTT
bool manageAWSConnection();
// Subscribe topic
bool manageAWSSubscription();
// Publish message to topic
bool publishMessage();
	Serial.begin(74880);
	while(!Serial){}
	Serial.flush();
	// WIFI_SSID, WIFI_PASSWORD Stored on wifi_credential.h file
	WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
	Serial.print("Connecting to ");
	Serial.print(WIFI_SSID); Serial.println("");
	int i = 0;
	while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
		Serial.print(++i); Serial.print('.');
	Serial.println('\n');
	Serial.println("Connection established!");
	Serial.print("IP address:\t");
	Serial.println(WiFi.localIP());         // Send the IP address of the ESP8266 to the computer
	if (manageAWSConnection()){
unsigned long lastSendingTime = millis();
unsigned long sendMessageEveryMillis = 5000;
	clientMQTT.loop();
	if (lastSendingTime+sendMessageEveryMillis<millis()){
		publishMessage();
bool manageAWSConnection(){
	// Configure WiFiClientSecure for the AWS IoT device certificate
  BearSSL::X509List cert(AWS_CERT_CA);
  BearSSL::X509List client_crt(AWS_CERT_CRT);
  BearSSL::PrivateKey key(AWS_CERT_PRIVATE);
	// Connect to the MQTT broker on the AWS endpoint
	clientMQTT.begin(AWS_IOT_ENDPOINT, 8883, client);
	// Create a message handler
	clientMQTT.onMessage(messageCallback);
	Serial.print("Connecting to AWS IOT");
	while (!clientMQTT.connect(THINGNAME)) {
		Serial.print(".");
		delay(100);
	if(!clientMQTT.connected()){
		Serial.println("AWS IoT Timeout!");
		return false;
	return true;
bool manageAWSSubscription(){
	  // Subscribe to a topic
	  if (clientMQTT.subscribe(AWS_IOT_SUBSCRIBE_TOPIC)){
		  Serial.println("AWS IoT Connected!");
		  return true;
	  }else{
		  Serial.print("AWS IoT ERROR: ");
		  Serial.println(clientMQTT.lastError());
		  return false;
void messageCallback(String &topic, String &payload) {
	Serial.println("incoming: [" + topic + "]" );
	Serial.println("---------------------------" );
	StaticJsonDocument<200> doc;
	deserializeJson(doc, payload);
	serializeJsonPretty(doc, Serial);
	// Create simple message
	DynamicJsonDocument doc(512);
	doc["time"] = millis();
	doc["deviceName"] = "esp8266";
	doc["status"] = "OK";
	char jsonBuffer[512];
	serializeJson(doc, jsonBuffer); // print to client
	Serial.print("Message on ");
	Serial.print(AWS_IOT_PUBLISH_TOPIC);
	Serial.print(" topic... ");
	// Publish message to AWS_IOT_PUBLISH_TOPIC
	if (clientMQTT.publish(AWS_IOT_PUBLISH_TOPIC, jsonBuffer)){
		Serial.println("Published!");
		return true;
	}else{
		Serial.println("Error!");
		return false;
This is my output:
IP address: xxx.xxx.x.xxx (hidden on purpose)
Connecting to AWS IOT.............
I think the issue is very small, something that I overlooked, but I cannot imagine what. If there are any details that I can provide, please let me know.
Help is greatly appreciated. Thanks!
I found that using the BearSSL library (as necessary with ESP8266) requires an NTP time to be set to validate the X509 certificates AWS IoT uses. Here's a link to a post that talks about this.
Simple connect function from the linked post:
  while (!timeClient.update()) {
    timeClient.forceUpdate();
  net.setX509Time(timeClient.getEpochTime()); // Important !
  net.setTrustAnchors(&cert);
  net.setClientRSACert(&client_crt, &key);
  client.setServer(ENDPOINT, 8883);
  Serial.println("Connecting to AWS IOT");
  while (!client.connect(THING_NAME)) {
    Serial.print(".");
  if (!client.connected()) {
    return;
any updates?
