Esp8266 2-pin button not working correctly
Hi guys i have one of those 2 pin buttons and im trying to connect it to my nodemcu 8266, using this code:
//in setup:
pinMode(16, INPUT_PULLUP);
// in update:
  int but1 = digitalRead(16);
  if(but1 == HIGH){ }else{
    Serial.print("BUTTON Low");
when i press the button once it goes from HIGH to LOW and stays on LOW forever unless i restart or replugg the 8266, any ideas?
one pin is connected to ground and the other to GPIO 16 on the esp8266
What does that mean ?
Please post your full sketch
what happens if you try this code?
(GPIO 16 not the best choice as D0 has a special status)
const byte buttonPin = 16;
  pinMode(buttonPin, INPUT_PULLUP);
  int buttonStatus = digitalRead(buttonPin);
  if (LOW == buttonStatus) {
    Serial.println("BUTTON IS LOW");
that is the full sketch
I beg to differ. For a start, the code that you posted has no setup() or loop() functions
didnt change anything, should i use another pin? here is the pinout of my board:
yes connect to D4 and use this code
const byte buttonPin = D4;
ensure the wiring is D4 --- button ---- GND
