Hi Arduino Pro's!
I am pretty new on Arduino. I did some Minor Projects using LED and Buzzer and WIFI - everything worked really fine.
Now I want to replace a RF remote Control using my ESP8266. Therefore I bought a RF Sender and a receiver Module.
AS a first step I want to read Out the codes the remote is sending using the Receiver. I found a Webpage where someone is doing exactly the same with his ESP8266.
I tried but I don't receive anything...
I add my code and Setup. Could you please take a Look? I tried both 3V and 5V Connection because the Guy of Webpage uses 3V but my receiver seems to need 5V.
ESP8266 Receiver Code For 315MHz And 433MHz
Wiring
ESP Receiver
3.3V = VCC
GND = GND
D3 = Data
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
mySwitch.enableReceive(0); // Connect To GPIO0 (D3) On The ESP
int value = mySwitch.getReceivedValue();
if (mySwitch.available()) {
Serial.print(" The Device Code Is: ");
Serial.println(mySwitch.getReceivedValue());
// output(mySwitch.getReceivedValue(), mySwitch.getReceivedBitlength(), mySwitch.getReceivedDelay(), mySwitch.getReceivedRawdata(),mySwitch.getReceivedProtocol());
mySwitch.resetAvailable();
