Everything is working very well. Though I’m surprised the ESP8266 is getting an IP Address of 192.168.4.1.
I would’ve expected it to be 1.1 or maybe 1.2 or something.
Can someone help me understand the logic this will use to assign IPs? I’d like to know because I’m planning to have several NodeMCUs all connected to a hotspot, then I will connect a laptop to the hotspot and write some “autodiscover” logic that will send requests to /Discovery and look for 200 responses to discover what IP addresses are active. So I need to know what heuristic to use for the ipaddresses I will send requests to. Thanks.
Where can I find what the default range is? I noticed from the above doucmentation I can set the initial address, gateway, and subnet, but how do I see / set what the range is it will assign?
The documentation says the max number of connected stations is 8?? Does that mean I can only have up to 8 clients connected to the hotspot network? Why is that limit there? That makes my scenario not work since I'm likely to have more than 8 nodes in my project....
the ESP8266WiFi library doesn’t expose the SoftAP DHCP settings. you could use the SDK API
larrywal32:
2. The documentation says the max number of connected stations is 8?? Does that mean I can only have up to 8 clients connected to the hotspot network? Why is that limit there? That makes my scenario not work since I’m likely to have more than 8 nodes in my project…
the esp8266 doesn’t have the resources CPU and RAM.
Thanks - bummer but appreciate it. Can you help me understand what you mean by “use the SDK API”? I don’t need to set it I just want to know with high probability what the range it will use is…
reading the source code I see, that WiFi.softAPConfig sets the range as IP + 99 to IP + 199. by default the softAPConfig is called with the library default IP address 192.168.4.1. (Espressif's default in SDK is 192.168.240.1)
so the assigned addresses with library defaults start at 192.168.4.100
