Esp8266 audio library not wokring
I did a test with the esp8266audio library but why doesn't it work on the SD Card and Speaker?
WEMOS D1 MINI
#include <Arduino.h>
#ifdef ARDUINO_ARCH_RP2040
void setup() {}
void loop() {}
#else
#include "AudioFileSourceSD.h"
#include "AudioGeneratorMP3.h"
#include "AudioOutputI2SNoDAC.h"
// For this sketch, you need connected SD card with '.flac' music files in the root
// directory. Some samples with various sampling rates are available from i.e.
// Espressif Audio Development Framework at:
// https://docs.espressif.com/projects/esp-adf/en/latest/design-guide/audio-samples.html
// On ESP8266 you might need to re-encode FLAC files with max '-2' compression level
// (i.e. 1152 maximum block size) or you will run out of memory. FLAC files will be
// slightly bigger but you don't loose audio quality with reencoding (lossles codec).
// You may need a fast SD card. Set this as high as it will work (40MHz max).
#define SPI_SPEED SD_SCK_MHZ(40)
File dir;
AudioFileSourceSD *source = NULL;
AudioOutputI2SNoDAC *out = NULL;
AudioGeneratorMP3 *decoder = NULL;
  audioLogger = &Serial;
  source = new AudioFileSourceSD();
  out = new AudioOutputI2SNoDAC();
  decoder = new AudioGeneratorMP3();
  // NOTE: SD.begin(...) should be called AFTER AudioOutputSPDIF()
  //       to takover the the SPI pins if they share some with I2S
  //       (i.e. D8 on Wemos D1 mini is both I2S BCK and SPI SS)
  #if defined(ESP8266)
    SD.begin(SS, SPI_SPEED);
  #else
    SD.begin();
  #endif
  dir = SD.open("/");
  if ((decoder) && (decoder->isRunning())) {
    if (!decoder->loop()) decoder->stop();
    File file = dir.openNextFile();
    if (file) {
      if (String(file.name()).endsWith(".mp3")) {
        source->close();
        if (source->open(file.name())) {
          Serial.printf_P(PSTR("Playing '%s' from SD card...\n"), file.name());
          decoder->begin(source, out);
          Serial.printf_P(PSTR("Error opening '%s'\n"), file.name());
      Serial.println(F("Playback from SD card done\n"));
#endif
