Check the connection between the Arduino and the ESP8266
If you see the following sequence of commands after the Arduino reset in the Serial Monitor, this means that the ESP8266 initialization is successful and there is a connection between the Arduino and the ESP8266:
AT
AT+RST
ATE0
AT+CWMODE=2
AT+CWDHCP=0,1
AT+CWSAP="RemoteXY","12345678",10,4
AT+CIPMODE=0
AT+CIPMUX=1
AT+CIPSERVER=1,6377
i connected the esp8266 and i can't get the same response as there mentioned..
i only get
AT
AT+RST
it's didn't connect with mobile phone also. what's the problem.
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP8266_HARDSERIAL_POINT
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_WIFI_SSID "RemoteXY"
#define REMOTEXY_WIFI_PASSWORD "12345678"
#define REMOTEXY_SERVER_PORT 6377
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,1,0,0,0,13,0,8,13,0,
1,0,45,19,12,12,36,31,88,0 };
// this structure defines all the variables of your control interface
struct {
// input variable
uint8_t button_1; // =1 if button pressed, else =0
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
#define PIN_BUTTON_1 12
RemoteXY_Init ();
pinMode (PIN_BUTTON_1, OUTPUT);
// TODO you setup code
RemoteXY_Handler ();
digitalWrite(PIN_BUTTON_1, (RemoteXY.button_1==0)?LOW:HIGH);
// TODO you loop code
// use the RemoteXY structure for data transfer
