Hey everyone, here's what I got.
ESP8266-12E (actually built by NodeMcu, but the pinout is same as the link)
https://acrobotic.com/acr-00018
LED strip uses WS2811 chip
The code I borrowed from works and partially works with the mods I made. I'll just post the sections I changed, but the complete code is here.
I also attached my code, to run you can download everything from the link above and just replace the original ino file with mine.
What it does
The original code connects to the wifi
Uploads a control page when you point a separate browser to it's IP
Changes the pattern/colors with your input
My changes
The original program is setup for one long LED strip which I tested to verify everything worked.
I then cut the strip into three sections for under cabinet lighting. I want them each on their own pin so I can control the delay between them (by making strips seem longer than they are).
The second one we don't have to answer here cuz I haven't even tested yet is an interrupt for a PIR sensor to change the lighting to white when someone walks near the counter. I hope it will go back to the pattern after a delay (10s for testing)
The issue
The problem is after cutting the strip and connecting, not all three strips light together.
(to the best of my memory from last night)
With all 3 in, only strip 1 works
Unplug strip 3 causes 1 and 2 to work
Unplug strip 2 causes 1 to work and 3 still doesn't work
Unplug strip 1 causes 3 to work and 2 still doesn't work (I think it was that order)
Each strip alone works in their respective pins
Keep in mind the original setup with one long strip did work just fine.
Code changes (with a little on either side to help find it in the original code)
This first section was modified to account for different strips with different lengths
// the very next line is original, but I commented out to add data pins later
//#define DATA_PIN 8 // for Huzzah: Pins w/o special function: #4, #5, #12, #13, #14; // #16 does not work :(
#define LED_TYPE WS2811
#define COLOR_ORDER BRG
#define STRIP_1 6 // seperate strips are numbered and added together to form one long chain
#define STRIP_2 67 // by adding extra leds, you add a delay so you don't jump a gap between strips too fast
#define STRIP_3 27
#define STRIP_12 STRIP_1 + STRIP_2
#define NUM_LEDS STRIP_1 + STRIP_2 + STRIP_3
#define MILLI_AMPS 10000 // IMPORTANT: set here the max milli-Amps of your power supply 5V 2A = 2000
#define FRAMES_PER_SECOND 120 // here you can control the speed. With the Access Point / Web Server the animations run a bit slower.
Next section was just setting up a pin for an interrupt
// My own interrupt
const byte interruptPin = 5;
FastLED.addLeds was originally one line that is now 3. After posting this in here, I see that I use pin 5 twice. Using pins 6,7,8 for data previously had yielded the same results though.
FastLED.addLeds<LED_TYPE, 5, COLOR_ORDER>(leds, 0, STRIP_1); // for WS2812 (Neopixel)
FastLED.addLeds<LED_TYPE, 6, COLOR_ORDER>(leds, STRIP_1, STRIP_2);
FastLED.addLeds<LED_TYPE, 7, COLOR_ORDER>(leds, STRIP_12, STRIP_3);
Checking for interrupt and calling function
// My own interrupt
pinMode(interruptPin, INPUT);
attachInterrupt(digitalPinToInterrupt(interruptPin), illuminate, RISING);
Interrupt function at the very end of the program
// My own interrupt
void illuminate()
fill_solid(leds, NUM_LEDS, solidColor); // turns on the default solid color (white)... full brightness?
FastLED.show();
delay(10000); // waits before going back to the palettes?
Disclaimer: I'm a mechanical engineer that didn't pay attention in school when we did the little programming req'd (hindsight on that one sucks). Anyway, I spent the last week and a half going through C++ tutorials and examples to get this far. Writing is going to be bad, but at least I recognize what 1/2 of the program is doing now. ![]()
esp8266-fastled-webserver.ino (23.5 KB)
