Esp8266 counter
Hello everyone I would like to ask you for help. I want to make a bidirectional counter with esp8266 using a ultrasound sensor. Then when it reach a certain number to send the data to a database. And then to display the data on webb page as a pop-up. I have litl knowledge about programming I found code for the counter and how to send to databases but I don't know how to combine them.. I spent almost 8 hours on searching but to much for me......
EDIT:I don't uploaded the codes because I am no able to combine them. What I found about sending data to mysql was discussed about other sensors/projects
Your topic was MOVED to its current forum category which is more appropriate than the original
You can spend Your entire life programming and still have things to learn.
Please read thhe topic "How to get the best from forum". Then update Your post.
I read it but I can't give you the codes if I wasn't able to test it because I can't understand how to put them together. If I omitted something then apologise. My English isn't perfect
Then test the codes and return here.
If you do not provide the code - so you expect that somebody write a code for you from scratch? This is not a way that the forum works.
Or you can find somebody who do it for you and should be ready to pay for the work.
If you agree with it - I will move you message to Paid Jobs Category of the forum.
Sorry for late reply i didn't had time.I changed ultrasonic to switches and sending counter data to mysql with no issue. But i want to send a text instead of a number for exemple if counter reach 5 then prepare if 10 then start just i can't figure out how to do that.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <Wire.h>
const char* ssid = "INFOS_Jurcsik";
const char* password = "tojure29het";
const char* serverName = "http://localhost/post-sensor-data.php";
String apiKeyValue = "tPmAT5Ab3j7F9";
String reference = "7590";
String lis = "I7046";
const int buttonPin0 = 0;  //D3
const int buttonPin1 = 5;  //D1
const int buttonPin2 = 4;  //D2
const int buzzerPin = 14;  //D5
int currentState0;  // variable for reading the pushbutton status
int currentState1;  // variable for reading the pushbutton status
int currentState2;  // variable for reading the pushbutton status
int pushCounter = 0;    // counter for the number of button presses
int resetCounter = 10;  // reset counter
int lastState0 = HIGH;  // previous state of the button
int lastState1 = HIGH;  // previous state of the button
int lastState2 = HIGH;  // previous state of the button
  Serial.println("Push Button Counter");
  Serial.println(" ");
  pinMode(buttonPin0, INPUT_PULLUP);
  pinMode(buttonPin1, INPUT_PULLUP);
  pinMode(buttonPin2, INPUT_PULLUP);
  pinMode(buzzerPin, OUTPUT);
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  if (pushCounter == resetCounter) {
    dataHTML();
    tone(buzzerPin, 1500, 300);  // buzzer turn on
    delay(300);
    tone(buzzerPin, 2000, 300);
    delay(300);
    tone(buzzerPin, 2500, 900);
    pushCounter = 0;
  if (pushCounter <= resetCounter) {
    buttons();
void dataHTML() {
  if (WiFi.status() == WL_CONNECTED) {
    WiFiClient client;
    HTTPClient http;
    http.begin(client, serverName);
    http.addHeader("Content-Type", "application/x-www-form-urlencoded");
    String httpRequestData = "api_key=" + apiKeyValue + "&reference=" + reference + "&lis=" + lis + "&batch=" + pushCounter + "";  //String httpRequestData = "api_key=theiotprojects&reference=7590&lis=I7044&pushCounter=12";
    Serial.print("httpRequestData: ");
    Serial.println(httpRequestData);
    int httpResponseCode = http.POST(httpRequestData);
    if (httpResponseCode > 0) {
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
      Serial.print("Error code: ");
    http.end();
    Serial.println("WiFi Disconnected");
    //Send an HTTP POST request every 20 seconds
    // delay(900);
void buttons() {
  currentState0 = digitalRead(buttonPin0);
  currentState1 = digitalRead(buttonPin1);
  currentState2 = digitalRead(buttonPin2);
  //IF BUTTON '0' AND '1' LOW AND BUTTON 2 HIGHT THEN COUNT +1
  if (currentState0 != lastState0) {
    if (currentState1 != lastState1) {
      if (currentState0 == LOW && currentState1 == LOW && currentState2 == HIGH) {
        pushCounter++;
        Serial.println(pushCounter);
  //IF BUTTON '0' AND '2' LOW AND BUTTON 1 HIGHT THEN COUNT -1
    if (currentState2 != lastState2) {
      if (currentState0 == LOW && currentState2 == LOW && currentState1 == HIGH) {
        pushCounter--;
  lastState1 = currentState1;
  lastState2 = currentState2;
  delay(50);
