ESP8266 error message when installing library
Hi, I have researched everywhere around the below error message I get from my arduino IDE when tried to install the ESP8266 library. I tried wkith different versions linking to the github website (as opposed to the latest version on below esp8266.com site. I still get the same error message as below. I also tried to delete everything else in the Arduino15 folder, except the preferences.txt, on which I have also tried to change boardsmanager.additional.urls from the address below to nothing (as suggested in some posts).
Nothing has worked. What should I do?
thanks!
Error downloading http://arduino.esp8266.com/stable/package_esp8266com_index.json
Error downloading https://downloads.arduino.cc/packages/package_index.json
Follow the steps at Installing ESP8266 in Arduino IDE (Windows, Mac OS X, Linux) | Random Nerd Tutorials
Hi @emonter. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Close all Arduino IDE windows.
  2. Start the Arduino IDE. (this restart was done to get a blank console pane)
  3. Select Tools > Board > Boards Manager from the Arduino IDE's menus.
  4. After the process fails, click the Close button.
  5. Click on the black console pane at the bottom of the Arduino IDE window.
  6. Press Ctrl+A to select all the text.
  7. Press Ctrl+C to copy the selected text to the clipboard.
  8. Open a forum reply here by clicking the Reply button.
  9. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  10. Press Ctrl+V. This will paste the compilation output into the code block.
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the Reply button to post the output.
Thank you so much Dozie. the comma separated urls did the trick!.
https://dl.espressif.com/dl/package_esp32_index.json, http://arduino.esp8266.com/stable/package_esp8266com_index.json
Thanks again
