ESP8266 Error: Rst cause: 2, boot mode: (3,6)
This code I have been using for my dry box for 3D printer filament has stopped working on a different ESP8266 module. I used this code on a previous ESP8266 module (I purchased a pack of three on amazon) and then I accidentally blew something on the original module. So I just switched it out after updating some code and now the code doesn't seem to work. Here is the code I have been using:
#include <Adafruit_AHTX0.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_AHTX0 aht;
Adafruit_SSD1306 display(128, 64, &Wire, -1);  // Declare and initialize the display object
uint32_t delayMS = 100;
const int PETG_TEMP = 65;
const int HEAT_FAN_RELAY = 13;
const int EXIT_FAN_RELAY = 15;
const int HEATER_RELAY = 12;
  // if (!aht.begin()) {
  //   Serial.println("Could not find AHT? Check wiring");
  //   while (1) delay(10);
  // Serial.println("AHT10 or AHT20 found");
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // Initialize the display
  pinMode(HEAT_FAN_RELAY, OUTPUT);
  pinMode(EXIT_FAN_RELAY, OUTPUT);
  pinMode(HEATER_RELAY, OUTPUT);
void displayTempHumid() {
  delay(delayMS);
  sensors_event_t humidity, temperature;
  aht.getEvent(&humidity, &temperature);
  float temp = temperature.temperature;
  float humid = humidity.relative_humidity;
  Serial.print("Temperature: ");
  Serial.print(temp);
  Serial.println("°C");
  Serial.print("Humidity: ");
  Serial.print(humid);
  Serial.println("%");
  display.clearDisplay();
  display.setTextColor(SSD1306_WHITE);
  display.setTextSize(1);
  display.setCursor(0, 0);
  display.print("Temperature: ");
  display.setCursor(0, 10);
  display.setTextSize(2);
  display.print(temp);
  display.print(" C");
  display.setCursor(0, 30);
  display.print("Humidity: ");
  display.setCursor(0, 40);
  display.print(humid);
  display.print(" %");
  display.display();
  digitalWrite(HEAT_FAN_RELAY, HIGH);
  digitalWrite(EXIT_FAN_RELAY, HIGH);
  digitalWrite(HEATER_RELAY, temp < PETG_TEMP ? HIGH : LOW);
  if (temp <= PETG_TEMP * 0.95) {
    digitalWrite(EXIT_FAN_RELAY, LOW);
    Serial.println("Heater = On, Heat Fan = On, Exit fan = Off");
  } else if (temp < PETG_TEMP) {
    Serial.println("Heater = ON, Fans = ON");
    Serial.println("Heater = Off, Fans = On");
  displayTempHumid();
I have the if statement at the beginning of void setup() to ensure my temperature and humidity sensor is connected. If its not, it will get into that loop and print out that it didn't detect the sensor. However, this print line never shows in the serial monitor. Here is the error when I keep that if statement commented out:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
11:13:13.596 ->
11:13:13.596 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
11:13:13.596 ->
11:13:13.596 -> load 0x4010f000, len 3424, room 16
11:13:13.596 -> tail 0
11:13:13.596 -> chksum 0x2e
11:13:13.596 -> load 0x3fff20b8, len 40, room 8
11:13:13.628 -> tail 0
11:13:13.628 -> chksum 0x2b
11:13:13.628 -> csum 0x2b
11:13:13.628 -> v00045d40
11:13:13.628 -> ~ld
11:13:13.698 -> ���e�N�|er��n|�$ ��$ #��� ��r�d�N� �o� l`��s�p��$e�  �
Let me know if you require anymore from me to diagnose the issue. Thanks!
Looks like a power issue.
How did that happen ?
So I was dumb and plugged in my usb when the power supply capacitors were still charged, created some power loop in the ESP8266 module and something popped. Whenever I measured with my multimeter Im still getting proper power to the new ESP8266 so I am unsure how it would be a power issue.
Biffing a boot pin or not looping.
Rubbish.
I'm sorry to say but none of that is very useful to me. The ESP 8266 works with another code I have to test and see what I2C connections I have but won't work for the code I posted.
