Hey all I am trying to see how long I can possibly have a ESP8266 ESP-07 operate with only 1 or 2 of the Lithium Ion Battery 18650 Cell which claims to have 2600mAh.
I am making a window alarm sensor and I'm looking to incorporate a window reed switch in order to check it's status via the ESP8266 and if its opened (meaning the window is not closed) then send something via WIFI to a REST service. Likewise, if the reed switch is not opened (meaning the window is fully shut) then sleep.
The flow with only ESP-07 would look something like this:
1: Power up for the first time.
2: Send Date/Time, window closed or opened, etc.. via ESP-07 WIFI to the REST service.
3: Have the ESP-07 go into deep sleep mode.
4: Wake up from sleep after 1 minute.
5: Check window reed switch.
6: If reed switch is open then send REST service via ESP-07 WIFI.
7: Goes back into deep sleep mode.
8: Loop back to #4.
The flow with ESP-07 & ATTiny85 would look something like this:
1: Power up ESP-07/ATTiny85 for the first time.
4: Have ATTiny85 check every 30 seconds for window reed switch status.
5: If reed switch is open then send REST service via ESP-07 WIFI.
6: ESP-07 goes back into deep sleep mode.
7: Loop back to #4.
It would seem that using the ESP8266 along side an ATTiny85 would make it last longer since I could check the status of the reed switch via the ATTiny85 and if it see the window closed then pause and check it again in 1 minute. If the ATTiny85 does see the reed switch opened then start up the ESP8266 and send the info via WIFI then go back into deep sleep. However, I am not sure how this would be on the battery side of things - if it would be less or same or more.
I'm looking to see how long 1 and/or 2 of the Lithium Ion Battery's would last (in days) with using just the ESP-07 and also using both the ESP-07 and the ATTiny85 as explained above.
I've done some googling and found a few websites that show how to put the ESP-07 into deep sleep mode but really wouldn't say how long it would take with my setup above. Most were using standard AA or AAA batteries.
The overall goal is: Have the window alarm power last at least 1 year.
The items:
The battery ESP-07 consumption chart I found:
Datasheets:
ATTiny85
Window Reed Switch (Generic) or Mouser (Generic)
ESP8266 ESP-07
