ESP8266 ESPAsyncTCP Error
Hi, suport highly appreciated !!
Using Arduino IDE I tried several standard codes with included ESPAsyncTCP.h library( e.g. ESP8266 NodeMCU Web Server with Slider: Control LED Brightness (PWM) | Random Nerd Tutorials ) without any changes and with all of them I got following (or similar) error message :
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
libraries\ESPAsyncTCP-master\ESPAsyncTCP.cpp.o: In function `__gnu_cxx::new_allocator<std::_Sp_counted_deleter<ACErrorTracker*, std::__shared_ptr<ACErrorTracker, (__gnu_cxx::_Lock_policy)0>::_Deleter<std::allocator >, std::allocator, (__gnu_cxx::_Lock_policy)0> >::allocate(unsigned int, void const*)':
C:\Users\Hans\Documents\Arduino\libraries\ESPAsyncTCP-master\src/ESPAsyncTCP.cpp:1194: undefined reference to `std::nothrow'
libraries\ESPAsyncTCP-master\ESPAsyncTCP.cpp.o: In function `_Sp_counted_base':
C:\Users\Hans\Documents\Arduino\libraries\ESPAsyncTCP-master\src/ESPAsyncTCP.cpp:1194: undefined reference to `operator new(unsigned int, std::nothrow_t const&)'
libraries\ESPAsyncTCP-master\ESPAsyncTCP.cpp.o: In function `AsyncServer::_accept(tcp_pcb*, signed char)':
collect2.exe: error: ld returned 1 exit status
exit status 1
Fehler beim Kompilieren für das Board NodeMCU 1.0 (ESP-12E Module).
I checked the library folder, I tried several versions of the library, I tried several examples, always error messages with reference to ESPAsyncTCP.h
Thanks for help !
Regards Hans
If your ESP8266 core is about as ancient as your IDE version that might explain the problems. I don't have an ancient core of the ESP8266, a current version does provide the std::nothrow functionality.
Thanks a lot, I loaded IDE V 2.1, but the same problem occurs. I’m wondering because the ESPAsyncTCP library is 4 years old. How to update ESP8266 core?
Best regards
Hans
Thanks a lot, after upgrade to ESP8266 core 3.1.2 it worked..
Best regards Hans
