Hi guys,
It's the first time for me working with Firestore I want to turn the LED light ON and OFF from firestore through the userID so the work in code has been done by createDocument and getDocument, and it works fine, but the issue here the LED light wont turn ON or OFF.
I might be mistaken with my approach, so here is the Serial monitor results and code you can find it below:
Serial Monitor Results:
Get a document... ok
"name": "projects/smart-tank-ea899/databases/(default)/documents/esp/1klR12zX5yN6bG9VbhTEfopEuoC2",
"fields": {
"pump": {
"stringValue": "off"
"createTime": "2021-12-02T09:53:49.929163Z",
"updateTime": "2021-12-02T10:27:27.579671Z"
"fields": {
"pump": {
"stringValue": "on"
"updateTime": "2021-12-02T10:32:16.830375Z"
Code:
#if defined(ESP32)
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#endif
#include <Firebase_ESP_Client.h>
#include <addons/TokenHelper.h>
/* 1. Define the WiFi credentials */
#define WIFI_SSID "Abdallah Agha"
#define WIFI_PASSWORD "abdallah123"
/* 2. Define the API Key */
#define API_KEY "AIza**************************"
/* 3. Define the project ID */
#define FIREBASE_PROJECT_ID "s**********************"
/* 4. Define the user Email and password that alreadey registerd or added in your project */
#define USER_EMAIL "a@a.com"
#define USER_PASSWORD "123456"
//Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
String uid;
String path;
String firebaseStatus = "on";
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
Serial.printf("Firebase Client v%s\n\n", FIREBASE_CLIENT_VERSION);
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the user sign in credentials */
auth.user.email = USER_EMAIL;
auth.user.password = USER_PASSWORD;
/* Assign the callback function for the long running token generation task */
config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
Firebase.begin(&config, &auth);
Firebase.reconnectWiFi(true);
//LED LIGHT
pinMode(D1, OUTPUT);
// Getting the user UID might take a few seconds
Serial.println("Getting User UID");
while ((auth.token.uid) == "") {
Serial.print('.');
// Print user UID
uid = auth.token.uid.c_str();
Serial.print("User UID: ");
Serial.println(uid);
//Create Document
FirebaseJson content;
//PUMP document is here
content.set("fields/pump/stringValue", firebaseStatus);
//esp is the collection id, user uid is the document id in collection info.
path = "esp/"+uid+"";
Serial.print("Create document... ");
if (Firebase.Firestore.createDocument(&fbdo, FIREBASE_PROJECT_ID, "" /* databaseId can be (default) or empty */, path.c_str(), content.raw()))
Serial.printf("ok\n%s\n\n", fbdo.payload().c_str());
Serial.println(fbdo.errorReason());
//Get Document
path = "esp/"+uid+"pump";
String mask = "pump";
Serial.print("Get a document... ");
if (Firebase.Firestore.getDocument(&fbdo, FIREBASE_PROJECT_ID, "", path.c_str(), firebaseStatus)){
if(firebaseStatus == "on"){
digitalWrite(D1, HIGH);
if(firebaseStatus == "off"){
digitalWrite(D1, LOW);
else{
delay(100);
