So habe jetzt mit dem Arduino Uno mein Receiver Modul abgehört und alle 6 Tasten der Fernbedienung Dokumentiert, keine Probleme mit der Lib oder dem Receiver. Den Wemos juckt es wenig, dass er >inzwischen< nur noch 433Mhz senden soll.
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(12);
// Optional set pulse length.
mySwitch.setPulseLength(321);
// set protocol (default is 1, will work for most outlets)
// mySwitch.setProtocol(2);
// Optional set number of transmission repetitions.
// mySwitch.setRepeatTransmit(15);
pinMode(12,OUTPUT);
mySwitch.send("000000000001010001010001");
digitalWrite(12,HIGH);
digitalWrite(12,LOW);
delay(10000);
Und hier die Dokumentierten AN AUS auf der Fernbedienung.
Reihenfolge> Zeile 1 bis 2 = an | Zeile 3 bis 4 = aus usw.
Decimal: 1361 (24Bit) Binary: 000000000000010101010001 Tri-State: 000000FFFF0Fþ PulseLength: 321 microseconds Protocol: 1
Raw data: 9976,272,1008,276,1004,276,1000,284,1004,280,996,284,1000,280,1004,280,1004,276,1012,272,1008,276,1000,920,364,280,1012,912,364,276,1012,916,372,268,1016,912,372,272,1016,908,368,916,376,912,368,916,376,912,368,
Decimal: 1364 (24Bit) Binary: 000000000000010101010100 Tri-State: 000000FFFFF0þ PulseLength: 321 microseconds Protocol: 1
Raw data: 9972,280,1000,280,1004,276,1004,280,1000,284,1004,280,1000,284,1004,280,1000,284,1004,276,1004,280,1000,924,372,268,1012,916,364,276,1004,924,368,276,1004,920,368,276,1008,924,364,916,368,916,372,916,364,920,368,
Decimal: 4433 (24Bit) Binary: 000000000001000101010001 Tri-State: 00000F0FFF0Fþ PulseLength: 321 microseconds Protocol: 1
Raw data: 9964,288,996,280,996,288,996,288,992,292,996,284,996,288,996,288,1000,280,1000,284,996,288,992,932,360,284,1000,924,364,280,996,928,364,280,1000,928,360,280,1008,920,356,928,368,920,360,924,360,924,364,
Decimal: 4436 (24Bit) Binary: 000000000001000101010100 Tri-State: 00000F0FFFF0þ PulseLength: 321 microseconds Protocol: 1
Raw data: 9964,288,992,288,996,284,1000,284,992,292,996,284,996,288,992,284,996,288,1000,280,1000,284,996,932,356,284,1004,920,356,288,1000,928,364,276,1008,920,356,284,1000,924,364,924,368,920,368,916,360,928,372,
Decimal: 5201 (24Bit) Binary: 000000000001010001010001 Tri-State: 00000FF0FF0Fþ PulseLength: 321 microseconds Protocol: 1
Raw data: 9964,288,996,276,1000,284,996,288,1000,280,1008,276,1000,280,1000,284,1000,280,1000,284,1000,284,1004,920,360,280,1004,924,364,276,1012,916,368,272,1004,924,364,280,1004,920,364,924,368,916,368,920,364,920,368,
Decimal: 5204 (24Bit) Binary: 000000000001010001010100 Tri-State: 00000FF0FFF0þ PulseLength: 321 microseconds Protocol: 1
Raw data: 9972,280,1000,280,1000,280,1004,280,1000,280,1000,284,1000,280,1000,280,1004,280,1004,276,1004,280,1004,924,360,280,1008,920,364,276,1004,924,364,280,1012,912,368,276,1004,920,368,920,360,924,364,924,364,920,368,
Die Pins sind entsprechend diesem Link aufgeteilt. Die Steckdose ist direkt neben dem 433Mhz Sender, was ist falsch?
Verschiedene Pins habe ich bereits versucht
gibt es vlt eine Version mit TX für den Sender?
Verschiedene Binarys zu senden habe ich auch schon versucht.
