ESP8266 GET JSON data from the server parsing.
Hi, Guys
I am using esp8266 with arduino using AT commands to get json data from a file named data.json on a hosting service.
Here is the code
#include <SoftwareSerial.h>
const byte rxPin = 2;
const byte txPin = 3;
String ssid = "MY_SSID";
String password = "MY_PASS";
SoftwareSerial esp8266 (rxPin, txPin);
String path = "/data.json";
String server = "wsiproject995.000webhostapp.com";
String getRequest = "GET " + path + " HTTP/1.1\r\n" + "Host: " + server + "\r\n" + "Connection: keep-alive\r\n\r\n";
String getRequestLength = String(getRequest.length());
String response="";
  esp8266.begin(9600);
  reset();
  //setMode("1");
  connectWifi();
  esp8266.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");
  if(esp8266.find("OK")) Serial.println("TCP Connection Ready");
  esp8266.println("AT+CIPSEND=" + getRequestLength);
  if(esp8266.find(">")) {
    Serial.println("Sending Request...");
    esp8266.print(getRequest);
  if(esp8266.find("SEND OK")) Serial.println("Request Sent");
  while(!esp8266.available()) {};
  espRead();
  esp8266.println("AT+CIPCLOSE");
  if(esp8266.find("OK")) Serial.println("TCP Connection Closed");
  delay(5000);
void espRead() {
  String c;
  while(esp8266.available()) {
    c = esp8266.readString();
    Serial.print(c);
void espClear() {
    esp8266.read();
void reset() {
  Serial.println("Resetting WiFi");
  esp8266.println("AT+RST");
  if(esp8266.find("OK")) Serial.println("Reset!");
void connectWifi() {
  espClear();
  Serial.println("Connecting...");
  String CMD = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
  esp8266.println(CMD);
  if(esp8266.find("OK")) Serial.println("Connected");
  else Serial.println("Couldn't connect to WiFi");
void setMode(String mode) {
    Serial.println("Setting Mode = " + mode);
    esp8266.println("AT+CWMODE=" + mode);
    espRead();
and here is the response
+IPD,369:HTTP/1.1 200 OK
Date: Wed, 29 Mar 2017 01:59:13 GMT
Content-Type: application/json
Content-Length: 41
Last-Modified: Tue, 28 Mar 2017 14:32:57 GMT
Accept-Ranges: bytes
Server: awex
X-Xss-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Request-ID: b7864810f7110d2fd22278ddb9c8ebeb
{"relay":"OFF","current":10,"energy":200}
OK
Now as you can see I am getting the json data but I am also getting a weird OK at the last line which doesn't happen in the examples that I've seen online
My question is how to get the data get stored in a String variable so I can parse it using some library.
I've tried using readStringUntil("\r\n\r\n") but the OK doesn't go away.
Help.
Thanks
Have you resolved this? It would be helpful for me.
