ESP8266 Node MCU erroe
okay, Firstly I'm trying to do this,(watch this video)
https://www.youtube.com/watch?v=N5JVQ-m5Kd0&t=649s
I did exact same things which he's doing. plus I'm windows 7 user.
My actual problem starts at 8:38(pause the video at it and have a look.)
in his Video it is showing (Updating XXX bytes n blah blah blah) at 8:38.
but in mine, this error is occurring,(the COM 3 port is choosen which is only i can select & use). (Which is only appearing.)
error
Sketch uses 522510 bytes (50%) of program storage space. Maximum is 1044464 bytes.
Global variables use 51560 bytes (62%) of dynamic memory, leaving 30360 bytes for local variables. Maximum is 81920 bytes.
warning: espcomm_send_command: wrong direction/command: 0x00 0x08, expected 0x01 0x08
warning: espcomm_sync failed
error: espcomm_open failed
I did Everything right just when I reached at this uploading part the problem occurred.
I have this chip -> https://www.amazon.com/HiLetgo-Version-NodeMCU-Internet-Development/dp/B010O1G1ES/ref=sr_1_3?ie=UTF8&qid=1487921045&sr=8-3&keywords=ESP8266
2nd. I'm not a Engineer, just a 12 Science student and I don't even have stuffs to do Advance check.
I explained My exact problem,
hope you guys will help...
Did you try the troubleshooting guide?
I Hope You will not find support here to build a wifi jammers. this is a pain in the *ss for everyone and illegal in most countries
I find it GREAT news you are failing miserably for lack of skills, imagination and knowledge.
Go do something else useful with your time and life and forget this totally stupid project
