Hi all,
I have esp8266 installed with homekit library
Everything works really well till modem restarts
As checked esp8266 reconnects wifi but homekit doesn’t restart and goes ‘no response’
I have to manually restart esp8266 to make it work everytime.
Is it possible to restart homekit when wifi disconnect and reconnect or simple restart esp8266 when wifi disconnect and reconnect?
Thanks
J-M-L
2
Thanks i tried already reading it but in homekit library there is no code with mdns
In that article says removing stop mdns will solve issue but in my case there is not at all mdns code present.
How i can command to restart esp if wifi disconnect and reconnect
J-M-L
4
ESP.restart(); tells your ESP to reboot, it's a clean reboot (versus ESP.reset() is a hard reset but can leave some of the registers in the old state)
And how to trigger if wifi disconnect/reconnect?
J-M-L
6
something like this in the loop (probably) will check the status and attempt to reconnect every 20 seconds
wl_status_t checkWifi() {
static unsigned long lastConnect=-20000ul;
// checking for WIFI connection
if ((WiFi.status() != WL_CONNECTED) && (millis() – lastConnect >= 20000ul)) {
Serial.println("Damned. Got disconnected. Reconnecting to WIFI network");
WiFi.disconnect();
WiFi.reconnect();
lastConnect = millis();
return WiFi.status();
checkWifi() ;
// other stuff here
system
Closed
7
