ESP8266 or arduino nano Send serial data and external power for RGB led.
Hi, my question it´s the following
I Need external power for a RGB led strip of WS2812B, but also I need to have my board conected to usb to send serial data for leds controll.
I have and esp8266 + 3.3to 5V logic converter.
And 5V output arduino nano.
How can I connect the RGB strip to power suply and arduino to usb without problems?
In this case if I connect the usb at same time I can burn my PC USB I understand, so what I need to change in order to have both usb and power at same time.
Thanks!
Remove the red wire between the Arduino and the LED power supply. Leave the ground (black) wire connected.
The 5V ano is a better choice for this.
Thanks!!!
I can't speak for the esp8266, mostly because there are a lot of different boards.
But connecting 5V to the 5V/Vcc pin of a Nano is fine. On a Uno it's unfortunately not... There you need >7V on the Vin for it to work. Safest option on a Uno is to:
  • or make a USB cable connected to the external 5V as well. Swap between USB to computer (when you need a computer) and USB from external PSU (when you want to run it without computer). Don't forget to do have a fixed connection between Arduino GND and external power GND.
  • or make a dedicated USB cable for the computer with the 5V wire cut. But don't forget to never use a normal USB cable
  • or find the trace of the 5V USB on the Arduino and cut it.
