ESP8266 Timed out waiting for packet header
Hey so I'm a noob and am trying to connect my Arduino Uno to my wifi with an ESP8266 ESP-01S (I've attached to pinout below)
I've downloaded the ESP8266 board for the IDE and have connected the ESP to my Arduino board as:
VCC - 3.3V
CH_EN - 3.3V
RX - TX
TX - RX
GND - GND
Here is my code:
#include <ESP8266WiFi.h>
  WiFi.begin("Wifi-address", "Wifi-Password");
  Serial.print("Connecting");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.print("Connected, IP address: ");
void loop() {}
yet whenever i try to upload the code, I get the error message :
Arduino: 1.8.13 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 236720 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26892 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 788 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24968 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 265652 bytes (27%) of program storage space. Maximum is 958448 bytes.
Global variables use 27008 bytes (32%) of dynamic memory, leaving 54912 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM3
Connecting......................................____Traceback (most recent call last):
File "C:\Users\Deepak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in
esptool.main(cmdline)
File "C:/Users/Deepak/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/Deepak/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
option enabled in File -> Preferences.
If anyone could help me out it would be greatly appreciated.
