Hi i was trying to upload sketch to esp8266 but error has occured,
For background i checked the port was detected and scelected in arduino ide overall everything connects ,drivers are fine it detects the programing chip.
ERROR MESSAGE:
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 231500 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26217 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1496 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 876 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25520 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 260089 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27892 bytes (34%) of dynamic memory, leaving 54028 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM6
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 48:55:19:14:ae:61
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Traceback (most recent call last):
File "C:\Users\kgrzy\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in
esptool.main(cmdline)
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3599, in main
detect_flash_size(esp, args)
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2848, in detect_flash_size
flash_id = esp.flash_id()
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 688, in flash_id
return self.run_spiflash_command(SPIFLASH_RDID, b"", 24)
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 948, in run_spiflash_command
old_spi_usr = self.read_reg(SPI_USR_REG)
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 562, in read_reg
val, data = self.command(self.ESP_READ_REG, struct.pack('<I', addr))
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 386, in command
p = self.read()
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 331, in read
return next(self._slip_reader)
File "C:/Users/kgrzy/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2636, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
Failed uploading: uploading error: exit status 1
